  3. Changing width of a toolbar typein item
  • Views 14160
Dmitry Babin
Dmitry Babin over 12 years ago
Hi all,
I've created a toolbar with a typein item using hiCreateToolbarTypein(). I want this field's width to change dynamically to accomodate the text I type in there. My approach was to use hiGetTextWidth("label" toolbar->typein_item->value) to calculate the new width (in units of pixel) and to assign this value to toolbar->typein_item->width.
The problem is, that the assignment apparently does not work. I type in CIW:
 ==> 100
 toolbar->typein_item->width = 200
 ==> 200 (new value returned)
 ==> 100 (but the old value is actually kept ! )
Does anyone have any suggestions?
Dmitry
    Dmitry,
    I don't believe this is currently possible - other than recreating the toolbar item. You should contact customer support so that an enhancement CCR can be filed.
  • Dmitry Babin
    Thanks Andrew,
    I'll file an SR.
    Dmitry
