  3. Saving a layout to a file using SKILL code
  • Views 15554
thomas1000
thomas1000 over 12 years ago
 I need to save a backup copy of a layout to a software-selected file using SKILL code - how do I do that?
    dbSave() takes optional additional arguments. It can either be dbSave(cvId destCvId) or dbSave(cvId libName cellName viewName). See the documentation for more detail.
    If it's a graphical application, you can also use geSaveAs().
  • thomas1000
     Thanks for your help.  geSaveAs() worked but dbSave() was needed because geSaveAs() would not accept a variable for the library name - it had to be a string literal.
    We'd have had to work quite hard to make geSaveAs() not take variables and only literal strings. I just tried it, and it worked perfectly:
    lib="opamp090"
    cell="adc_sample_hold"
    view="layout_final_copied"
    win=hiGetCurrentWindow()
    geSaveAs(win lib cell view)
    I tried this in both IC5141 and IC615. Looking at the argument list and function type for geSaveAs, it simply can't not accept variables - it's a normal (lambda) function, and so arguments are evaluated before it is called.
