  3. How to retrieve via spacing of a 2x2 customVia in Virtuoso...
  • Views 14204
How to retrieve via spacing of a 2x2 customVia in Virtuoso?
chianga
chianga over 12 years ago
I am trying to write a SKILL routine that increase and descrease number of vias with bindkeys.  I got the routine to work with stdVia but I am running into some problems with customVias.  In stdVia, you can retrieve cutspacing by using the following command:
stdVia=car(geGetSelSet())
stdVia->viaHeader->overrideParams
which outputs  ("cutSpacing" (0.07 0.07)) along with other via information
However, when I use the same command on a 2x2 customVia, there is no cutSpacing information.  I noticed this only happens on a 2x2 via, when a via is 3x3 or bigger the cutSpacing information does appear under overrideParams.
 I am wondering if anyone knows why this is the case and if there are other ways I can retrieve the spacing information.
Andy
 PS I am using IC6.1.5-64b.500.12
    Andy,
    With a custom via, the exact parameter is dependent upon the implementation of the custom via. In the one I tried, the parameters are called yCutSpacing and xCutSpacing - and are only set in overrideParams if they've explicitly been altered (i.e. increasing the rows and columns doesn't alter them - I don't really see why it would know; that intelligence would normally be built into the pcell, I'd have thought).
    So you might be able to work it out from other technology constraints - but it is likely to be very dependent upon the implementation of the custom via.
  • chianga
    Thanks again for your explanations.  As you have mentioned, the customVia pcell has a lot of intelligence built in already, for example, the justification is already built in whereas std via the justification is done with originOffset so I didn't need to do much to get my code working besides viaSpacing, which I managed to pull off the tech file.
    If I want to learn more about customVia, can you point me to the documentation on how to impletment it?  I tried to search Cadence documentation with "customVia" without much of the luck.  I have also went over the tech file and again all the implementation is pretty standard like viaSpacing, overlap, etc.  I am curious on how thing like justification is implemented on customVia.
    Cheers,
    Andy
