  3. Is the a way we can access library which is not define in...
  • Subscribers 148
  • Views 17816
Is the a way we can access library which is not define in cds.lib
kb how
kb how over 12 years ago
Hi all,
Good day.
May i know is the a way we can access a library which is not defined in cds.lib?
Let's say i have a local common library, and i wanted to do some testing on user workspace. Without touching/modify user's cds.lib, i want to access my local common library and do some verification on user workspace.
Do cadence (SKILL) has such capability?
    You could use ddSetForcedLib() to point at another cds.lib file which contains a reference to your library. Or run "virtuoso -cdslib /path/to/your/cds.lib". Otherwise, no.
  • kb how
    Thanks Adrew,
    If this is the case, means i cant pull in any library (not included in cds.lib) into my database. =(
  • kb how
    Hi Adew,
    I created a skill code (cheat way) which read current working directory cds.lib and create a new cds.lib at /tmp by addding the newLib path as below. Is this recommended?
    ; Description:
    ;  Cheat way to define other library into your current working directory without
    ;  touching user's cds.lib. It will create a temporary cds.lib file and set the file as new
    ;  cds.lib file.
    ; Date: 01.17.2013
    procedure( update_cdslib( newLib newLibPath "tt")
       let(( line cdslib newfile inp outp)
          unless( isDir(newLibPath)
             error("Input newLibPath %L not exist\n")
          );unless
          cdslib = ddGetForcedLibEx(nil)
          when( cdslib == "" || !isFile(cdslib)
             cdslib = strcat(getWorkingDir() "/cds.lib")
          );when
          sprintf(newfile "/tmp/cds.lib_%s" buildString(parseString(getCurrentTime() ": ") ""))
          inp = infile(cdslib)
          outp = outfile(newfile)
          while( gets(line inp)
             fprintf(outp "%s" line)
          );while
          fprintf(outp "\n\n# New added by %s at %s\n" getLogin() getCurrentTime())
          fprintf(outp "DEFINE %s %s\n" newLib newLibPath)
          close(inp)
          close(outp)
          when( isFile(newfile)
             ddSetForcedLib(newfile)
          );when
          ddUpdateLibList()
       );let
    );proc
    Seems reasonable. I've donesimilar things in the past.
  • kb how
    Thanks. This is the best i can think of.
