  3. Skill code to apply instance orientation to a cordinate
  • Views 15147
shajujan
shajujan over 12 years ago
I'm looking to extract label cordinates of an instance based on how the instance is placed, i.e, after factoring in the orientation of the instance. Has anyone written code like this? For eg. x:y = 10:20 would become -10:20 after MY, 20:10 after MYR90
Shaju
  • kb how
    kb how over 12 years ago
    You can use dbTransformPoint to transform the point.
  • dmay
    dmay over 12 years ago
    More specifically:
    xy=10:20
    dbTransformPoint(xy list(0:0 "MY"))
    dbTransformPoint(xy list(0:0 "MXR90"))
    Derek
  • shajujan
    Thanks Derek. I got it to work.
     procedure( dumpPins( file )
            let( (inst cv fp x pins pin)
            inst = car(geGetSelSet())
            ;Required because I want to open the layout view, if instance is xform
            cv = dbOpenCellViewByType(inst~>master~>libName inst~>master~>cellName "layout")
            if( cv then
                fp = outfile(file)
                pins = setof( x cv~>shapes (x~>objType=="label" && x~>lpp=='("AP" "pin")) )
                foreach( pin pins
                         ;Displacement occurs after mag is applied
                         xy = dbTransformPoint(pin~>xy list(inst~>xy inst~>orient inst~>mag))
                         fprintf( fp "%s\t%f\t%f\n" pin~>theLabel float(round(car(xy))) float(round(cadr(xy))) )
                dbClose(cv)
                close(fp)
                printf( "dumpPins: found %d pins in %L\n" length(pins) cv~>cellName )
            else
                printf( "dumpPins: ERROR: Could not open %s/layout\n" cv~>cellName )
