  3. Release the memory by skill
  • Subscribers 152
  • Views 16083
nidon
nidon over 12 years ago
Hi everyone,
 I write a skill code to generate a lot of pcells,but the speed of the generation become slower and slower.
And I think it may be generated large memory by the code,so how can I release these memory to improve the the speed of generation?
Tks a lot~
  • Quek
    Quek over 12 years ago
    Hi Nidon
    I think in general, you can try disabling "undo" and using dbClose on unused cellviews to reduce memory consumption of skillscripts. It is a little hard to know the cause of the actual problem without looking at the codes. : )
    Best regards
    Quek
  • nidon
    Ths for your reply,quek
    In the fact,I have been used dbClose/dbSave and undoLimit in my code,but it seems doesn't work.And the whole code as follow:
    procedure(LeeGenResdrc(parampath list_pdk)
        let((gen_process num_model numbers_of_inst res_log cellId respath inres list cricut
             second forth param_begin_w param_end_w param_begin_l param_end_l list_multi grid multi_num
             z aaa bbb list_fingers j factor step param_add param_adda param_addb list_param_w list_l
             num_l i value list_connection list_boolean num_con num_boolean num_fingers list_w
             total_num num_row num_col calu value_key row beg end ref_x ref_y para counts model_list
             list_pa ele_pa ele_aa list_aa ele_nw)
             gen_process=hiCreateWindow(nil "text" "Generate Process File")
    ;         hiDisplayWindow(gen_process)
    ;        hiSetWindowName(gen_process strcat(runDir libName_gds ".log"))
             num_model=length(list_pdk)
             numbers_of_inst=1
             res_log=strcat(ddGetObjReadPath(ddGetObj(LibName)) "/../pdk_miss.log")
             miss_list=list_pdk
             hiSetUndoLimit(0)
             foreach(bjt list_pdk
                 cellId=dbOpenCellViewByType(LibName strcat(bjt "_pdk_drc_all") "layout" "maskLayout" "w")
                 respath=strcat(parampath bjt "/")
                 inres=infile(strcat(respath "cell.cdf"))
                 list=ncons(nil)
                 model_list=ncons(nil)
                 cricut=t
                 while(cricut
                    cricut=gets(line inres)
                    list=append1(list line))
                 close(input)
                 list=remove(nil list)
                 counts=1
                 foreach(para list
                     list_pa=parseString(para "(")
                     if(counts<=2 then
                        foreach(ele_pa list_pa
                           list_aa=parseString(ele_pa " ")
                           if(list_aa=='("cdfCreateParam") then counts++ )
                           if(length(list_aa)>=1 then
                               foreach(ele_aa list_aa
                                  if(ele_aa=="?choices" then
                                      list_bb=parseString(para " '(\"")
                                          foreach(ele_nw cdr(remd(car(last(list_bb)) list_bb))
                                                       ; remove the first and last element for list_bb
                                               model_list=append1(model_list ele_nw)
                                                  ) ; for
                                  ) ; if ele_aa
                                ) ; for
                              ) ; if
                            ) ; if
                          ) ; if
                        ) ; for extract the model choices from each bjt model parameters
                model_list=remove(nil model_list)
                printf("%L\n" model_list)
                list_multi=nil
                grid=0.005u
                multi_num=20
                z=0
                while(z<multi_num
                        z=z+1
                        aaa=sprintf(nil "%n" z)
                        bbb=list(aaa)
                        list_multi=nconc(list_multi bbb)
                list_col=list_multi
                list_row=list_multi
                list_param=nil
                param_num=60u
                j=0
                param_begin=3u
                factor=10
                while(j<=factor
                        step=float(param_num)/factor
                        param_add=float(param_begin)+j*step
                        param_adda=PasCeiling(param_add grid t)
                        param_addb=list(param_adda)
                        list_param=nconc(list_param param_addb)
                        j=j+1
                list_w=list_param
                list_l=list_param
                num_col=length(list_col)
                num_row=length(list_row)
                num_w=length(list_w)
                num_l=length(list_l)
                total_num=num_col*num_row*num_model
                num_col=fix(sqrt(total_num))
                num_row=round(total_num/num_col)
                i=1
                value=1
                spa_cell=250
                numbers_of_inst=1
                foreach( model_name model_list
                        foreach( col_choice list_col
                            foreach( row_choice list_row
                                    calu=(i-1)/num_col
                                    key=fixp(calu)
                                    value=(if key then calu else value)
                                    value=float(value)
                                    value_key=float(1)+value*num_col
                                    row=float(round(i/num_row))
                                    beg=1+row*num_col
                                    end=(row+1)*num_col
                                    ref_x=0
                                    ref_y=0-(value-1)*spa_cell
                                    if( i==value_key then
                                    instId=dbCreateParamInstByMasterName(cellId target_pdk bjt "layout" get_pname(concat("bjt_list" "_" i)) 0:0 "R0" 1
                                                      list(
                                                           list("model" "string" model_name)
                                                           list("col" "string" col_choice)
                                                           list("row" "string" row_choice)
                                    cdfGetInstCDF(instId)
                                        rodAlign(
                                            ?alignObj           rodGetObj(sprintf(nil "bjt_list_%n" i) cellId)
                                            ?alignHandle        'lowerLeft
                                            ?refPoint           list(ref_x ref_y)
                                    ) ;end if
                                    if( i!=value_key then
                                            list(
                                        rodAlign(
                                            ?refObj             rodGetObj(sprintf(nil "bjt_list_%n" i-1) cellId)
                                            ?refHandle          'lowerRight
                                            ?xSep               100
                                            ?maintain           nil
                                    ) ;end if
                                    i++
                        ) ;end foreach
                    ) ;end foreach
                    numbers_of_inst++
                ) ;end foreach
                     dbSave(cellId)
                     dbClose(cellId)
                     miss_list=remove(bjt miss_list)
                     setq(port outfile(res_log))
                     foreach(mis_res miss_list
                     fprintf(port "%s\n" mis_res)
                     close(port)
                     numbers_of_inst++
             ) ;end foreach
             deleteFile(res_log)
             file_path=strcat(ddGetObjReadPath(ddGetObj(LibName)) "/../")
             hiSaveViewfile(gen_process strcat(file_path "Generate_Process_File" ".log"))
      ) ; let
    ) ; procedure
    LeePdkPathCheck()
  • berndfi
    berndfi over 12 years ago
     Does ‘dbClose’ really purges cells  form memory?
    I always use ‘dbClose’ in combination with ‘dbPurge’, to be on the save side.
    dbSave(cellId)
    dbClose(cellId)
    dbPurge(cellId)
    Bernd
  • nidon
    Thank you~
    But I used the dbPurge,it seem still doesn't work
    And the code will become slower and slower~
  • marcelpreda
    marcelpreda over 12 years ago
     Hi there,
    Reading the 1st post looks like it is not 100% sure that the problem is memory.
    Better  to try the the skill profiler (license is needed).
    You can check with it which procedures are slow, but also you can check the memory used by each one.
    If you do not have license available for profiler you can try to monitor the process to see the allocated memory,
    with a command like `top' ; available on most unix flavors.
    Any how looking at the code.
    I do no know how large are your list, but a code like:
                 list=ncons(nil)
                 while(cricut
                 close(input)
    can be translated to
                 list = nil  ;; actually your list is already nil
                 while(cricut
                    list=cons(line list)
                 close(input)
    The idea is that cons is much faster than append1 when huge list is involved;
    cons() adds the element at the begining of the list.
    If the elements order matters you can do a
         list = reverse(list)
    Or you can try directly to use tconc() structure ;
    I personally I'm to lazy to use it :D - every time I should check the manual.
    You ca do the same thing with the other list where you also use append1.
    BR,
    Marcel
