  3. Form locked when callback fails
  • Views 14172
Danilo P
Danilo P over 12 years ago
The skill below is used to create a simple form containing a string field with a modifyCallback.
Eveything goes fine writing in the string field, but when the callback generates an error  (artificially reproduced typing "abc")  the form is locked and "OK"/"Cancel" buttons can't be used anymore. Once this happens, even if the form is invoked again or it is set to 'unbound in the CIW, the issue persists.
Could someone be so kind and explain me why this wrong behaviour?
Thank you
procedure(testMyForm()
let(()
    hiCreateAppForm(
            ?name 'test_form
            ?formTitle "TEST"
            ?fields list(
                  list( hiCreateStringField(?name 'myString ?prompt "->" ?modifyCallback "matchCB" ?editable t) 10:10 200:20 100 ))
            ?buttonLayout list( 'OKCancelDef)
            ?callback list(   "printf(\"OK\")" "printf(\"CANCEL\")")
      hiDisplayForm('test_form)
procedure(matchCB( @rest arg)
let(( )
      stringItem = test_form->myString->value
      if( equal(stringItem "abc") then
            printf("ERROR %s \n" )              ;;;; ERROR HERE, it locks the form
      else
            printf("Hello world %s \n" stringItem)
      t     ;any value is allowed in the string field
    It looks like a bug. I'll create a service request and a CCR for this (I think I know which "Danilo P" you are).
  • Danilo P
    any way to unbound via skill the form from the CIW when this happens? Something like test_form = nil.
    Just not to close dfII and start again to un-lock the form
    Thank you
    Danilo
    Danilo,
    hiFormDelete doesn't help, and setting it to 'unbound doesn't help. I also tried hiFormUnmap.
    You could use a new symbol for the form each time (which is a bit inconvenient). For example:
    let(()
       test_form=hiCreateAppForm(
                ?name gensym('test_form)
                ?formTitle "TEST"
                ?fields list(
                      list(hiCreateStringField(?name 'myString ?prompt "->" ?modifyCallback "matchCB" ?editable t) 10:10 200:20 100 ))
    That way the global variable test_form contains a handle to the form, but it's stored in a unique symbol each time it is created.
