  3. Editing a wire with Virtuoso Schematic
  • Views 18014
lartola
lartola over 12 years ago
I know it seems to be simple, but I can't change the name of wires in my schematic. I've tried to select the wire or the value of the name name and edit, but each time I've tried to change it, the name is not editable.
How could I fix that ?
Thanks in advance for your time.
  • skillUser
    skillUser over 12 years ago
    Hi Laurent,
    In a schematic a wire either derives a name from a schematic pin it is connected to, or from a label placed on the wire.  For the latter, edit the label, or if the name was a default name (e.g. "net1") then add a label to override it. If the wire is connected to a pin then the pin name would need to change to change the wire name (unless we are talking about a bus pin, in which case you can tap off specific sections by adding an appropriate name, e.g. pin is A<7:0> and a wire segment could be named A<3:0> as an example).
    Hopefully this answers your question?
    Lawrence.
  • lartola
    Hi Lawrence, Thanks for your help, it works perfectly now !
