  3. netlist modifications in ocean scripts
  • Views 13182
Lcorso
Lcorso over 12 years ago
I am trying to create an Ocean script for multiple simulation of analog and mixed signal circuits. The idea is to implement a modified netlist with aditional blocks from an initial one, but I've been realizing that the netlist seems to be created for every iteration on XL mode (I'm using IC6.1.5 with ADE XL) Is there a way to fix the modified netlist as an input for the script instead of generating itself on every Ocean.X history iteration?
I've tried by fixing the path on the design ("") command but it returns an error with the mapping of the cells.
Thanks a lot and best regards
