  3. to set a bind key to show/hide dummy/odummy
  • Replies 19
  • Views 11596
Weight66
Weight66 over 13 years ago
I'd  like to set a bind key to show/hide dummy/odummy, here is part of code:
procedure(ST_Lyt_ShowHide_Layers(Command PressedKey ShowDummy)       ;Available values for Command: >=1 to Add, <=1 to Remove and 0 to Hide all but selected one       ;Available values for ShowDummy: t to show dummy types and nil to keep dummy layers hidden       Lyt_Key_Layer_Assoc = '( ("0" 0) ("1" 1) ("2" 2) ("3" 3) ("4" 4) ("5" 5) ("6" 6) ("7" 7) ("8" 8) ("9" 9) ("`" 10) ("-" 11) )       Lyt_Sel_Layers = nth(nth(1 assoc(PressedKey Lyt_Key_Layer_Assoc)) Lyt_Layer_List)       Lyt_Show_Layer = nil       if((Command >= 0) then              leSetEntryLayer(list(nth(0 Lyt_Sel_Layers) nth(0 Lyt_Layer_Purposes)))              if((Command == 0) then                     leSetAllLayerVisible(nil)              )              foreach(Lyt_SLayer Lyt_Default_Layers                     foreach(Lyt_SPurpose Lyt_Layer_Purposes                           LytShowLayer = t                           if((Lyt_SPurpose == Lyt_Dummy_Purpose_Name) then                                  LytShowLayer = ShowDummy                           )                           leSetLayerVisible(list(Lyt_SLayer Lyt_SPurpose) LytShowLayer)                     )              )              Lyt_Show_Layer = t       )       if((Command >= -1) then              leSetEntryLayer(list(nth(0 Lyt_Default_Layers) nth(0 Lyt_Layer_Purposes)))       )       foreach(Lyt_SLayer Lyt_Sel_Layers              foreach(Lyt_SPurpose Lyt_Layer_Purposes                     LytShowLayer = Lyt_Show_Layer                     if((rexMatchp(strcat(".*" Lyt_Dummy_Purpose_Name ".*") Lyt_SPurpose) == t) then                           LytShowLayer = (ShowDummy && LytShowLayer)                     )                     leSetLayerVisible(list(Lyt_SLayer Lyt_SPurpose) LytShowLayer)              )       )       hiRedraw())
  • Weight66
    Hi Ted,
    I got the massage "no licence to run SKILL Develpoment", Thanks, Wei
  • theopaone
    theopaone over 13 years ago
     Check with you CAD group to see if you have a license. You may have to check it out manually.
    Otherwise, put printf statements in your code to check the values.
    Ted
  • Weight66
    Hi Ted,
    Is it OK to do
    Lyt_Dummy_Purpose_Name = ("dummy" "odummy")
  • skillUser
    skillUser over 13 years ago
    You will need either a single quote or the function "list" before the open parentesis otherwise you will get a syntax or run-time error:
    '("dummy" "odummy") or list("dummy" "odummy")
    Lawrence.
  • theopaone
     It is OK to set the value as a list but your test is an equivalence test not a list member test. You should be testing for a member rather than ==
    if( ( listp(Lyt_Dummy_Purpose_Name) and
          member( purpose Lyt_Dummy_Purpose_Name ) or
          purpose == Lyt_Dummy_Purpose_Name then
    Ted
  • kpai
    kpai over 13 years ago
    This is what I have for my code whih I modified from CCSToggle into CCSToggledmy
     procedure(CCSToggledmy(llist)
       let( (x)
         foreach(x llist
    if( leIsLayerVisible(list (x "odummy") && list(x "dummy1") && list(x "dummy"))
    then
       leSetLayerVisible(list(x "odummy") nil)
       leSetLayerVisible(list(x "dummy") nil)
       leSetLayerVisible(list(x "dummy1") nil)
       leSetLayerSelectable(list(x "odummy") nil)
       leSetLayerSelectable(list(x "dummy") nil)
       leSetlayerSelectable(list(x "dummy1") nil)
    else
       leSetLayerVisible(list(x "odummy") t)
       leSetLayerVisible(list(x "dummy") t)
       leSetLayerVisible(list(x "dummy1") t)
       leSetLayerSelectable(list(x "odummy") t)
       leSetLayerSelectable(list(x "dummy") t)
       leSetlayerSelectable(list(x "dummy1") t)
    ) ;if
          );foreach
          hiRedraw()
       );let
    ); procedure CCSToggledmy
    hiSetBindKey("Layout" "<Key>[" "CCSToggledmy(list(\"M1\" \"M2\" \"M3\" \"M4\" \"M5\" \"M6\" \"M7\" \"M8\" \"M9\" \"M10\"))")
    Hope this helps!
    Kathy =)
  • theopaone
    The following line will not work as leIsLayerVisible only takes a single argument and returns t or nil:
    You would need to write it like this:
    leIsLayerVisible(list(x "odummy")) && leIsLayerVisible(list(x "dummy1")) && leLayerIsVisible(list(x "dummy"))
    Ted
  • kpai
    That's odd !  This script works fine with me.
     The only thing that I notice I forgot to place hiRedraw() right after the );foreach line
    -Kathy
  • theopaone
     If it is working, only thing it is testing is the first argument value and ignoring the other values. I don't have access to Virtuoso so I can't test it at this time.
    Ted
