  3. Shift<Key>3 bindkey not working
  • Replies 11
  • Subscribers 154
  • Views 11809
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
 I was using this "Shift<Key>3" bindkey for some function, But its not calling that function, but if i change the Key with any other character it is. Can some one let me know what the problem could be.
Neeraj
    Andrew Beckett over 5 years ago in reply to J R PRASANTH +1
    The forum guidelines do ask you not to post on the end of an old (in this case 9 years old) thread. By default, you can't define bindkeys using Alt, because the Alt key is used for menu accelerators…
    By default, you can't define bindkeys using Alt, because the Alt key is used for menu accelerators (the underlined character in menus). So in the CIW if you do Alt-T-V-W it will bring up a ViVA waveform window.
    You can disable that by adding:
    ui enableMenuShortcuts boolean nil
    to your ~/.cdsenv (note it cannot be done in .cdsinit - it must be .cdsenv as it has to be done early enough in the initialisation). Then you can define bindkeys using Alt as part of the key sequence, but the menu accelerators can't be used.
