  3. Help regarding pop-push of a LIST
  • Replies 37
  • Subscribers 150
  • Views 33111
Neeraj Vardhan
Neeraj Vardhan over 13 years ago
I was trying to save my path coordinates as a list. But when i was trying to print the list of points, got errors "unbound variable-plist" . the code is mentioned below.
procedure(nvToGetMyLocation()
let((point plist)
cvw=getCurrentWindow()
point=hiGetPoint(cvw)
plist=append(plist list(point))
print(point)
print(plist)
); let
); procedure_nvToGetMyLocation
    Neeraj,
    Did you try the suggestion in my previous post? You don't necessarily have to add the leSetEntryLayer() in your bindkey definition - it could just be used to end and re-start the path and you can change the layer using the LSW (after you've restarted the path creation, since it only actually uses the entry layer when the path is created at the end).
  • Neeraj Vardhan
    Hi Andrew, I haven't tried it yet. I am Out of office today. I will try it and return back if i see any problem. Regards Neeraj
  • Neeraj Vardhan
    Andrew, I have tried your approach. But its very slow, the enterPath function has to end and recalled for every metal change. I am using a different approach, where i first save the path points and the entryLayer between the points. This makes my life simpler while routing. Is there any possible approach, where i use the enterPath function and it saves all the points for single click of mouse. and not depending on the direction change. Regards Neeraj
    Neeraj,
    I don't see it as being slow myself, but I'm not really sure what you're doing that is different from the code I sent. Maybe you could alter the  nvCreatePathDoneProc function so that rather than recording the list passed in each time, you record the new last point and add to the previous list - that would allow you to collect colinear points. However, using backspace to remove the last point wouldn't really work then, and it would be very confusing to the user, I think, unless you actually create the paths as you go along.
  • Neeraj Vardhan
    Andrew,
     I am saving all the points and the valid entry layer at that point first and then modifing the paths and via's according to the direction of the path is going. Yes, the way you mentioned also works great. I am currently trying it out to make sutable to what we want here.
    I just wanted to know why cant we add a mouse click co-ordinates also to the enterPath function. Just to improve my knowlege what could be possible wrong, if we do that.
    Regards
    Neeraj
    Hi Neeraj,
    This is probably because in general enterPath would be used to construct a single path, and co-linear points are not allowed in OA (and not desirable in CDB).
    So we don't (as far as I know) have any option to retain the co-linear points.
  • Neeraj Vardhan
    Thanks Andrew,
     Hope then, am left with only the option you stated. To break between every change of layer.
    Regards
    Neeraj
