  3. Help regarding pop-push of a LIST
  • Replies 37
  • Subscribers 150
  • Views 28779
Neeraj Vardhan
Neeraj Vardhan over 12 years ago
I was trying to save my path coordinates as a list. But when i was trying to print the list of points, got errors "unbound variable-plist" . the code is mentioned below.
procedure(nvToGetMyLocation()
let((point plist)
cvw=getCurrentWindow()
point=hiGetPoint(cvw)
plist=append(plist list(point))
print(point)
print(plist)
); let
); procedure_nvToGetMyLocation
  • skillUser
    skillUser over 12 years ago
    Hi Neeraj,
    I can't test your code right now, but one thing that springs to mind is that plist is a function, and possibly a special variable... As I read your code I don't see anything that would cause plist to be undefined - it is declared in the let statement, so it should always have a value in that scope, at the very least it would be nil.
    Try using a different name for the variable...
    Hope this helps,
    Lawrence.
  • Neeraj Vardhan
    Hi lawrence,
    I tried with different variable name, and got the below error. Hope i am doing some mistake as there are other functions too in this code.
    3.965 6.48)((3.965 6.48))
    (6.61 6.51)((6.61 6.51))
    (6.47 5.21)((6.47 5.21))
    (3.7 5.055)((3.7 5.055))
    (2.345 6.535)((2.345 6.535))
    (2.79 5.72)((2.79 5.72))
    s
    *Error* toplevel: undefined variable - s
    Neeraj
    I'm guessing that your code cannot be what you've posted, because that works fine. There's nothing wrong with it (well, apart from you using the obsolete getCurrentWindow() rather than hiGetCurrentWindow() - but that shouldn't cause any problems).
    Have you really loaded that version of the code? Or maybe your real code is more complicated than what you've posted?
  • Neeraj Vardhan
    I was trying to upload the code from morning, but failed to upload... below is the code i am  working on
    procedure(nvMyDirection()
    let((xy1 xy2 x1 x2 y1 y2)
    i=0
    for(i 1 n
    xy1=nth(i p_list)
    xy2=nth((i+1) p_list)
    x1=xCoord(xy1)
    y1=yCoord(xy1)
    x2=xCoord(xy2)
    y2=yCoord(xy2)
    if(x2-x1>0 && y2-y1 == 0 then print("RIGHT"))
    if(x2-x1<0 && y2-y1 == 0 then print("LEFT"))
    if(y2-y1>0 && x2-x1 == 0 then print("TOP"))
    if(y2-y1>0 && x2-x1 == 0 then print("BOTTOM"))
    print(xy1)
    print(xy2)
    print(x1)
    print(x2)
    ) ; for
    ) ; let
    ) ; procedure_nvMyDirection
    procedure(nvGetMyLayer()
    let((layer cur_layer)
    layer=leGetEntryLayer()
    cur_layer=append(cur_layer list(layer))
    ); let
    ); procedure_nvGetMyLayer
    procedure(nvGetMyLocation()
    n++
    prog((p_curt p_list)
    p_curt=hiGetPoint(cvw)
    p_list=append(p_list list(p_curt))
    print(p_curt)
    print(p_list)
    ); let
    ); procedure_nvGetMyLocation
    Not clear what your problem is now - please elaborate. You have four separate functions there, which are variously referring to global variable. For example, nvGetLocation is referring to a variable n which would need to be defined. nvMyDirection is referring to global variable p_list (which is not the same as the variable p_list in nvGetMyLocation, since that is local to the prog() call within that function).
    So what are you calling, and what is happening that is not what you expect?
  • Neeraj Vardhan
    "3.965 6.48)((3.965 6.48)) (6.61 6.51)((6.61 6.51)) (6.47 5.21)((6.47 5.21)) (3.7 5.055)((3.7 5.055)) (2.345 6.535)((2.345 6.535)) (2.79 5.72)((2.79 5.72))   error* toplevel: undefined variable - p_list"  this is the error its pouping up . And when i tried to print p_list it didnt return the list of points, insted it gave undefined variable-p_list
    Yes, but what functions are you running?
    If you're calling nvGetMyLocation() (assuming you have a variable n defined), then p_list will be set within that function, but will be discarded (and hence no longer defined) after the prog() has finished. So if you're then trying to look at p_list in the CIW, it will be undefined - hardly surprising since it is a local variable. Similarly if you call nvMyDirection() it will be looking for a global variable p_list, which won't be defined. If it was, then it could compute local variables xy1, xy2, x1, x2 (which are defined in the let()), but these will be thrown away when the let() exits and hence when nvMyDirection exits. If you then call nvMyPath, it won't know what xy1 and xy2 are - plus the fact that the code is wrong in this function because the list of points is improperly specified.
    So PLEASE explain what you're doing. Nobody can debug by reading your mind!
  • Neeraj Vardhan
    i am trying to create an auto_route function. For that, first i am saving my start and end points of the metal paths. So for that i started making a list of points with in p_list. And then accessing it later to create the path and vias. The direction will help me the VIA placement, so that it dont create a notch. I am just trying but it started failing from yesterday. when i started writing the rest of the code.. Regards Neeraj
    Neeraj,
    OK, but you still haven't said which functions you are calling, and in what order. In other words, the sequence of events that led to the error you saw.
  • Neeraj Vardhan
    i am using these key one by one to get the location and the entry layer at that moment.
    hiSetBindKey("Layout" "<key>1" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M1\")")
    hiSetBindKey("Layout" "<key>2" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M2\")")
    hiSetBindKey("Layout" "<key>3" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M3\")")
    hiSetBindKey("Layout" "<key>4" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M4\")")
    hiSetBindKey("Layout" "<key>5" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M5\")")
    hiSetBindKey("Layout" "<key>6" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M6\")")
    hiSetBindKey("Layout" "<key>7" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M7\")")
    hiSetBindKey("Layout" "<key>8" "nvGetMyLocation() nvGetMyLayer() leSetEntryLayer(\"M8\")")
    hiSetBindKey("Layout" "<key>e" "nvGetMyLocation() nvMyDirection()")
    Regards
    Neeraj</key></key></key></key></key></key></key></key></key>
