  3. how to enable turbo tool box in virtuoso 6.1.5
  • Views 13920
sritha
sritha over 12 years ago
Hi All,
I am unable to use turbo tool box in virtuoso 6.1.5.It is giving an error
error: *WARNING* (tb001002): Missing rules caused an error.
Run _leTbEnvValidator( <cellviewId> ) for details.
*WARNING* Turbo Toolbox will not work with the current design until its techfile is updated - (("*Error* Error"))
If I run the command give above i.e( _leTbEnvValidator( <cellviewId> ))
It is showing
------- TURBO TOOLBOX TECHFILE VALIDATOR -------
Copyright 2006 - Cadence Design Systems, Inc.
*WARNING* (tb001009): Invalid 1st parameter inCellView should be a cell view - 338588818
nil
could you please let me know the proceure to enable "Options->Toolbox"in virtuoso 6.1.5.
  • skillUser
    skillUser over 12 years ago
    How did you pass in the cellview database ID?  It looks as though this may have been typed in, rather than passing the dbId directly (i.e. did you type "338588818" as input to the function?). Try the following:
    _leTbEnvValidator(geGetEditCellView())
    Hopefully this will help you.
    Lawrence
