  3. hiCreateListField number display
  • Subscribers 150
  • Views 14014
imagesensor123
imagesensor123 over 12 years ago
    it return (3.5e-7 3.5e-7) in the form field which i create by the function hiCreateListField in skill with the value '(0.35um 0.35um), I prefer it display in the field  like (0.35um 0.35um), how to set the options? and could we get the results showing in the field without bracket?
regards,
zfeng
  • berndfi
    berndfi over 12 years ago
     The easiest approach, if you take the output formatting important, would be to use string fields
    rather than a list field. If you need the values for calculation you can process them with an "evalString".
    You have not wrote why the values should be in the form of 0.35um, which makes it difficult to give you a hint.
  • uttamkumar
    uttamkumar over 12 years ago
     this could be due to floating point numbers representation. 0.35 has a non-terminating binary expansion. More information regarding the numbers is needed to solve the problem.
    regards
    uttam
