  3. How to pass values from perl script to skill ?
  • Views 14320
siliconx
siliconx over 12 years ago
Hello everyone,
I have a perl script which is working on some text file. The output of the perl file are multiple arrays which contains length, minwidths and metal layers. On the other hand I have a skill script, Which I have been using to create layout. In skill I need to use the values from the perl script. So, I want to know that how can I access perl arrays or subroutine in skill? or is there any other way to do it ?
Thank you.
Varun
  • uttamkumar
    uttamkumar over 12 years ago
     you can use skill's Interprocess communication functions.There is a detailed documentation on this topic.
    Example:
     cid=ipcBeginProcess("perl filename")   //starts perl program execution from skill and returns a handle for the child process
      ipcWaitForProcess(cid)     //waits for child process
      while(ipcIsAliveProcess(cid)
                  printf("%s" ipcReadProcess(cid))   //read data from stdout
    ofcourse there are many other functions available that might be useful to you.
    regards
    uttam
  • theopaone
    theopaone over 12 years ago
    If using IPC, be sure to flush the buffer in Perl after writing to stdout. Othewise the data may not get to SKILL until the buffer is full or closed.
    A better way is to write to a file and then read in the file. You could use comma separated records, one line for each device and break them into a list for SKILL processing.
    Ted
