  3. pull down menu with directory contents
  • Subscribers 150
  • Views 14261
frogconsultant
frogconsultant over 12 years ago
Hi All,
 I looked through the community for inspiration on this subject but I cannot find a first step for it. I would like to have a field in one of my menu containing the directory content (list of file) either through a cyclic or pulldown field.
 Does someone could give me an idea of how to grab the content of a directory path through a field menu?
  • psill00
    psill00 over 12 years ago
    I am kinda doing this on the fly since this is pieced together. If there is an error post it and we will work through it. This creates or adds to the menus on the CIW. You can do something similar to the layout menus too.
    This setup lists a directory and loads a file when you click on the slider.
    Try this:
    Create a ~/menus
    Copy/Paste or create ciw.menus in the ~/menus directory
     daMenu      = '(myMenu "My Stuff" (
                    (trySlider      "Cool Stuff" (
                            (booya1        "Test1" "println(1)")
                            (booya2        "Test2" "println(2)")
                    )); end of Utilities menu
    loadFile  = '(lscr "mySkill" (
                    (skLintGui      "Lint"          "skShowForm()")
                    (cdsFind        "cdsFinder"     "startFinder()")
                    (skillIde       "Skill IDE"     "_ilgRunSkillIde()")
                    (refresh        "Refresh List"  "refreshMySkillMenu()")
                    (xscripts       "xScripts File" (
                            (holder "" "")
                    (virtuoso       "Virtuoso File" (
                            (holder "" "")
                    (bindkey        "Bindkey File"  (
                            (holder "" "")
                    )); end of loadFile
    localCiwMenu = '(daMenu loadFile)
    ciwMenuList = append(ciwMenuList localCiwMenu)
    Another copy and paste file and make sure it loads when you start cadence and execute skForum_custCiwMenuBuild().
    Example of what to put in your ~/.cdsint file
    load("FILE_PATH")
    Copy/Paste below:
    procedure(skForum_addFileMenuItems(@optional (bool nil))
    let(    (item fileItem
        (ext ".il$")
        (dir "ADD_YOUR_SKILL_DIRECTORY _HERE")
    foreach(file skForum_sortLastModified(dir ext t)
        item        = car(parseString(file "."))
        fileItem    = hiCreateMenuItem(?name stringToSymbol(item)
                        ?callback  strcat("load(\"" dir file "\")")
                        ?itemText file)
        hiAddMenuItem(xscripts fileItem)
    ); end of foreach
    hiDeleteMenuItem(xscripts 'holder)
    t
    ); end of let
    ); end of skForum_addFileMenuItems
    procedure(skForum_delFileMenuItems()
    let(    (tmp
    unless(member('holder hiGetMenuItems(xscripts))
        tmp = hiCreateMenuItem(?name 'holder ?itemText "tmp" ?callback "xB()")
        hiAddMenuItem(xscripts tmp)
    foreach(item    hiGetMenuItems(xscripts)
        unless(equal(item 'holder) hiDeleteMenuItem(xscripts item))
    t
    )); end of skForum_delFileMenuItems
    procedure(skForum_refreshMySkillMenu() skForum_delFileMenuItems() skForum_addFileMenuItems())
    procedure(skForum_sortLastModified(dir ext sort)
    let(    (fileList vFile tmp len
    foreach(file getDirFiles(dir)
        if(rexMatchp(ext file) fileList = cons(file fileList))
    if(sort then
        vFile    = listToVector(fileList)
        len    = length(vFile)-2
        for(i 0 len
            for(j 0 len
            if(greaterp(fileTimeModified(strcat(dir vFile[j])) fileTimeModified(strcat(dir vFile[j+1]))) then
                tmp        = vFile[j]
                vFile[j]    = vFile[j+1]
                vFile[j+1]    = tmp)
        reverse(vectorToList(vFile))
    else    sort(fileList nil))
    ); end of let
    ); end of skForum_sortLastModified
    procedure(skForum_reloadFile()
    let(    (file
        (dir "ADD_YOUR_SKILL_DIRECTORY_HERE")
    file = car(skForum_sortLastModified(dir ".il$" t))
    printf("Loading file... %s\n" file)
    load(strcat(dir file))
    )); end of skForum_reloadFile
    procedure(skForum_custCiwMenuBuild()
    let(    (item fileItem
        (virt "virtuoso/")
        (bind "bindkeys/")
        (loadDir "ADD_YOUR_SKILL_DIRECTORY _HERE")
    foreach(file skForum_sortLastModified(strcat(loadDir virt) ".il$" nil)
                        ?callback  strcat("load(\"" loadDir virt file "\")")
                        ?itemText file)
        hiAddMenuItem(virtuoso fileItem)
    ); end of foreach
    foreach(file skForum_sortLastModified(strcat(loadDir bind) ".il$" nil)
                        ?callback  strcat("load(\"" loadDir bind file "\")")
                        ?itemText file)
        hiAddMenuItem(bindkey fileItem)
    ); end of foreach
    hiDeleteMenuItem(virtuoso 'holder)
    hiDeleteMenuItem(bindkey 'holder)
    t
    ); end of let
    ); end of skForum_custCiwMenuBuild
  • frogconsultant
    Hi
    I tried the first skill. I am not having the extra pulldown or I am not sure I understand the outcome of your first skill.
    Regards, Fabian
