  3. How to write inline callback methods
  • Subscribers 150
  • Views 16222
TauStudent
TauStudent over 12 years ago
I'm writing a Form in skill for a university project, many of the controls in my form have a callback method which is very short
Example :
 EnableEddyRadioField = hiCreateRadioField(
   ?name 'EnableEddyRadio
   ?choices '("on" "off")
   ?prompt "Turn Eddy on/off:"
   ?value "off"
   ?callback list("EddyEnable(t)" "EddyEnable(nil)")
procedure(EddyEnable(bool)
 myForm->EddyTextField1->editable=bool
 myForm->EddyTextField2->editable=bool
writing this way makes pretty ugly code, so my question is if there a way to write the callback inline, something like that :
   ?value "off"
   ?callback list(
    (myForm->EddyTextField1->editable=t myForm->EddyTextField1->editable=t)
    (myForm->EddyTextField1->editable=nil myForm->EddyTextField1->editable=nil)
Thanks !
  • berndfi
    berndfi over 12 years ago
    To separate code into procedural pices is in my opinion not uggly,
    but here is an inline example.
    procedure( BFcreateEddyForm( )
        let( ( eddyStringField eddyRadioField )
    ;; creating the fields
        eddyStringField =
            hiCreateStringField(
                ?name       'eddyStringField
                ?prompt     "Eddy Text:"
                ?editable   nil
        eddyRadioField =
            hiCreateRadioField(
                ?name       'eddyRadioField
                ?choices    '( "On" "Off" )
                ?prompt     "Turn Eddy On/Off:"
                ?value      "Off"
                ?callback   list(
                                "hiGetCurrentForm( )->eddyStringField->editable = t"
                                "hiGetCurrentForm( )->eddyStringField->editable = nil"
    ;; creating the form
        hiCreateAppForm(
            ?name       '__eddyForm__
            ?formTitle  "Eddy Form"
            ?initialSize list( 300 260 )
            ?fields     list(
                        list(
                            eddyStringField
                            15:5 250:25 120
                        list(
                            eddyRadioField
                            15:50 250:25 120
    ) ;; close let
    ) ;; close procedure
    procedure( BFeddyForm( )
        unless( boundp( '__eddyForm__ ) && hiIsFormDisplayed( __eddyForm__ )
                BFcreateEddyForm( )
        hiDisplayForm( __eddyForm__ )
     And in your case you have two commands you want to do - so your callback could be:
    "myForm->EddyTextField1->editable=t myForm->EddyTextField2->editable="
    i.e. space separate them.
    In addition, in the upcoming IC616 release you'll be able to specify the callbacks as function objects, so you can create a lambda function (an unnamed inline function) to do this. Note that you can't do this in IC615. For example (adapting Bernd's code):
         let( ( eddyStringField1 eddyStringField2 eddyRadioField )
         eddyStringField1 =
                 ?name       'eddyStringField1
                 ?prompt     "Eddy Text 1:"
                 ?editable   nil
         eddyStringField2 =
                 ?name       'eddyStringField2
                 ?prompt     "Eddy Text 2:"
                 ?editable   nil
         eddyRadioField =
             hiCreateRadioField(
                 ?value      "Off"
                 ?callback
                    list(
                        lambda((field scope selection)
                            let((editable)
                                editable=if(selection=="On" t nil)
                                hiGetCurrentForm()->eddyStringField1->editable=editable
                                hiGetCurrentForm()->eddyStringField2->editable=editable
         hiCreateAppForm(
             ?name       '__eddyForm__
             ?fields     list(
                         list(
                             eddyStringField1
                             15:5 250:25 120
                         list(
                             eddyStringField2
                             15:35 250:25 120
                         list(
                             eddyRadioField
                             15:80 250:25 120
     ) ;; close let
                 BFcreateEddyForm( )
  • TauStudent
     Thanks, that's exactly what I needed !
