  3. open cell with maximize window
  • Subscribers 150
  • Views 17156
xuli230
xuli230 over 12 years ago
When I open a cell from library manager, it always was a small windown and not on top level,
is there any way to open a cell with maximize window and on top level? At least on top level ! Thanks
    Not sure what you mean by "not on top level". Maybe you mean it is not behind other windows? If so, this is probably a consequence of the focus stealing prevention behaviour setting. Which window manager are you using? (e.g. Gnome or KDE - but might be others).
    There are cdsenv settings to control window sizes. Put something like this in your ~/.cdsenv (adjust the coordinates to suit your needs):
    layout leWindowBBox string "((120 185) (1020 875))"
    schematic schWindowBBox string "((120 185) (1020 875))"
    schematic symWindowBBox string "((120 185) (1020 875))"
  • xuli230
    Thanks.as you said, not no top level meas the opened cell window is behind library manger. my window manger is Gnome.
    window size was solved.
    See this solution on Cadence Online Support.
  • djeto38
    djeto38 over 12 years ago
     Hello ,
    Same problem for me ....
    But the previous "solution" isn't readable .
    Andrew , Could you please send another link ?
    Thanks in advance
     Jerome
    Jerome,
    Not sure what went wrong there. I fixed the link in my previous post so it should work now.
  • djeto38
    Andrew ,
    Thanks a lot, now the link is readable.
    Jérome
