  3. Error has been getting while opening Virtuoso XL.
  • Views 15910
Sarvani
Sarvani over 12 years ago
 Hi All,
I am getting below error in CIW while opening virtuoso XL. And then XL not opening.  My version is 615. Could you please let me know the reason for this?
*Error* append: argument #1 should be a list or another acceptable type - t
 Thank you,
Sarvani
    Sarvani,
    Impossible to tell from that line alone. Best would be to contact customer support, but perhaps you can also try entering this in the CIW:
    _stacktrace=50
    tracelength=tracelevel=50
    sstatus(errsetTrace t)
    and then do the operation which causes the error. Post the full stacktrace that you get here:
  • Sarvani
    I don't have account in customer support. I'll inform this to my administrator and then suggest him to contact customer support. I got below error in CIW when I followed your code.
    *WARNING* hiGetSessionWindow: invalid window specified.
    *WARNING* (LX-2012): Environment variable 'initIOPinLayer' has an invalid value: 'MET1 drawing'.
    Using the default I/O pin layer 'ACTIVE drawing' instead.
    INFO (BND-1002): Binder initialization report:
    Schematic instances with corresponding layout instances: 0
    Layout instances with corresponding schematic instances: 0
    Layout instances with no corresponding schematic instance: 0
    Instances present in schematic but missing from layout: 8
    <<< Stack Trace >>>
    (... in _dePullMultiUserMenuTriggers ...)
    (... in __deCallUserMenuTrigger ...)
    (... in __deMakeBannerMenus ...)
    (... in _deCreateNewView ...)
    (... in _deNew ...)
    (... in lxiOpenFormCB ...)
    lxiOpenFormCB()
    progn(lxiOpenFormCB())
    hiFormDone(deNewForm)
    (... in _lxiHiSetup ...)
    (... in unknown ...)
    funobj@0x18d59078()
    (... in lxiMCVSchEnableTrigger ...)
    (... in _launchXLid ...)
    _launchXLid(winId "Virtuoso XL (Schematics)")
    lxLaunchLayoutXL()
    *Error* strcat: argument #2 should be either a string or a symbol (type template = "S") - nil
    <<< Stack Trace >>>
    (... in _rteGetToolbar ...)
    (... in _rteInitToolbar ...)
    _rteInitToolbar()
    funobj@0x18d59078()
    lxLaunchLayoutXL()
    <<< Stack Trace >>>
    _rteInitToolbar()
