  3. Is it possible to specify a variable with rexMatchp?
  • Views 17720
adeuser777
adeuser777 over 12 years ago
Can we have a variable with rexMatchp?
My requirement is as below:
a = "m_1"
b = '("m_1" "m_1_1" "m_1_2")
c = setof(i  b  !rexMatchp("_[1-9]*$" i)   // This will return nil.
My desired output for c is "m_1" and at the same time, I want to exclude a_[1-9] where a="m_1"
Could you please guide? Is it possible with rexMatchp?
Ram
  • skillUser
    skillUser over 12 years ago
    Hi Ram,
    I'm confused as to what you want, your requirements are mutually exclusive - you want to match "m_1" but you don't want to match a (which is "m_1") - can you clarify your requirement please?
    Probably the trick will be to either build the rexMatchp test expression using sprintf() where the variable can be inserted into the test expression [e.g. sprintf(nil "%s*$" a) ], and/or make a more complex condition which can be written as a single compound/composite expression [e.g. "this" || ("that" && "theOther") - this OR (that AND theOther) ].
    Anyway, I hope this helps you.
    Lawrence.
    I assume you want:
    rexCompile(strcat(a "_[1-9]*$"))
    c=setof(i b !rexExecute(i))
    This will return ("m_1")
  • adeuser777
    Sorry for not being clear. Let me explain what I am trying to do.
    "a" could fall under one of the following category.
    a = '(m1 m1_1 m1_2...)    or a = '(mn_1 mn_1_1 mn_1_2...)
    My end goal is to get the "original name (orig_name) with out _[1-9]. And if the original name itself had _[0-9] in it, I need to handle it appropriately.
    I have implemented the following to handle this scenario.
    rexCompile("_[0-9]$")
    if(rexExecute(orig_name) then mainInst = car(setof(i insts !rexMatchp("@" i) && !rexMatchp("_[0-9]_[1-9][0-9]*$" i)))
    else parentInst = car(setof(i insts !rexMatchp("@" i) && !rexMatchp("_[1-9][0-9]*$" i)))
    Is there a better way to handle this? Thanks.
    Your requirements are still as clear as mud, I'm afraid. I've really no idea what you are trying to achieve. Originally a was a string - now it is a list. Your example doesn't even mention a so I don't know what you are trying to do.
    Best thing is to describe a number of different sets of input and output data - with some detailed description of what you want it to do.
    Are you using IC61? If so, the pcre functions allow a lot more power in the regular expressions than the old rex functions.
  • adeuser777
    My apologies. I have corrected the description.
    "b" could fall under one of the following category.
    Case 1:
    b = '("/i0/i1/m1" "i0/i1/m1_1" "i0/i1/m1_2"...)
    a = "m1"
    Expected output = "i0/i1/m1"
    Case 2:
    b = '("/i0/i1/mn_1" "/i0/i1/mn_1_1" "/i0/i1/mn_1_2"...)
    a = "mn_1"
    Expected output = "i0/i1/mn_1"
    My end goal is to get the original name "a" with out _[1-9]. And if the original name itself had _[0-9] in it, I need to make sure, it's handled appropriately.
    if(rexExecute(a) then mainInst = car(setof(i b !rexMatchp("_[0-9]_[1-9][0-9]*$" i))
    else mainInst = car(setof(i b !rexMatchp("_[1-9][0-9]*$" i))
    The above lines are doing the job. Could you please let me know if there is a better way?
    Thanks.
    Isn't this just  rexMatchList(strcat(a "$") b) ? Or the car of that if you want the first match?
