  3. Using dbTransformBBox
  • Replies 11
  • Subscribers 150
  • Views 28782
kasyab
kasyab over 13 years ago
I am a relatively new user of SKILL. My problem is with the use of dBTransformBBox function. I am able to apply this function to scale the size of objects which are uniquely represented in bounding box fashion("rect" objects). My question is if this function is applicable to polygons as well.
Specifically when I apply  dBTransformBBox to a shape in the active layer there is no scaling. As far as I can tell these shapes differ only in that they are represented as "polygon" objects in terms of their geometry.  dBTransformCellView scales all layers in a cell view, so it should be possible to scale polygons as well. I tried to use the dbLayerSize function to achieve scaling on the active layer but I do not understand the results returned by it.cvID~>DBUPerUU returns 1000.0.I am attaching a couple of pictures that show the layout before and after the application of dbLayerSize and also some example code of what I used to achieve this.
 cv_lay = dbOpenCellViewByType("SEMIREG_STM040" "SR_FA" "layout" "" "a")
  shape_list = cv_lay~>shapes
  OD_shape_list = nil
  foreach(shape shape_list
    if(shape~>lpp == list("OD" "drawing") then
      OD_shape_list = append1(OD_shape_list shape)
    );if
  );for
 OD1=car(OD_shape_list)
 dbLayerSize(cv_lay "OD" list(OD1) 0.50)
 dbLayerSize(cv_lay "OD" list(OD1) -0.50) [returns nil]
 leLayerSize(cv_lay list("OD" "drawing") -0.50 list("OD" "drawing")) [also returns nil]
I looked at other posts referring to leLayerSize (which I see in the manual is a layout editor procedural version of the dbLayerSize function), but the problem of the sizing value is still present here. There is no hierarchy in my layout.
I also tried leSizeShape for the specific shape I extract above.
 OD1
db:0x15f30944
OD1~>objType
"polygon"
leSizeShape(0D1 0.50)
SYNTAX ERROR found at line 5363 column 16 of file *ciwInPort*
*Error* lineread/read: syntax error encountered in input
Any help will be appreciated.
Kasyab
original cell view
cellview after applying dbLayerSize with 0.5 sizing
cellview after applying leLayerSize with 0.5 sizing
  • kasyab
     Thanks Andrew. Your tips helped a lot. I have some issues with my machine right now and haven't been able to check out these commands, but I deinitely will when I have the chance.
    Kasyab
