  3. How do I clip a waveform vertically?
  • Views 19399
kitmonisit
kitmonisit over 12 years ago
It is possible to clip a waveform along the x-axis using the clip function. How do I perform a clip along the y-axis?
I'm trying to separately take the integral of all positive values and all negative values of a waveform, and vertical clipping is how I thought I'd do it.
    Don't think there's anything built in, but easy enough to implement something using the code below.
    For example, define:
    procedure(MyClipVal(val) cond((val<1 1) (val>4 4) (t val)))
    This is clipping anything below 1 or above 4. Then load the code below, and call abRegApplyToWaveSpecialFunction().
    You can then have your waveform in the calculator, bring up the SKILL User Defined Functions, pick abApplyToWave, and enter the function name as MyClipVal. See the attached picture which shows this in action.
    /* abApplyToWave.il
    Author     A.D.Beckett
    Language   SKILL
    Date       May 24, 2011
    Modified   A.D.Beckett
    By         May 31, 2011
    Function to apply a unary function to every element
    in a waveform. For example:
    abApplyToWave('round waveform)
    Can also add to the Skill User Defined Function using:
    SCCS Info: @(#) abApplyToWave.il 05/31/11.17:24:41 1.2
    *                  (abCreateApplyToWaveForm)                   *
    *      Create the form needed to enter the function name       *
    (defun abCreateApplyToWaveForm ()
      (let (func)
        (setq func (ahiCreateStringField
                     ?name 'func
                     ?prompt "Function"
                     ?value "round"
        (calCreateSpecialFunctionsForm
          'abApplyToWaveForm
          (list (list func 0:0 280:20 140))
    *               (abApplyToWaveSpecialFunctionCB)               *
    *            Callback for the registration function            *
    (defun abApplyToWaveSpecialFunctionCB ()
        ?formSym 'abApplyToWaveForm
        ?formInitProc 'abCreateApplyToWaveForm
        ?formTitle "Apply to Wave"
        ?formCallback "abApplyToWaveFormCB()"
    *                       (abApplyToWaveFormCB)                       *
    * Callback for the form. Bit complicated because need the arguments *
    * to be with the waveform not first, and with a single quote before *
    *                        the function name.                         *
    (defun abApplyToWaveFormCB ()
      (let (form)
        (setq form (hiGetCurrentForm))
        (calCalcInput
          'expression
          (sprintf nil "abApplyToWave('%s %s)"
                   (concat (getq (getq form func) value))
                   (calGetBuffer))
        t
    *                (abRegApplyToWaveSpecialFunction)                *
    * Function to actually register the user defined special function *
    (defun abRegApplyToWaveSpecialFunction ()
      (calRegisterSpecialFunction
        (list "abApplyToWave" 'abApplyToWaveSpecialFunctionCB)
      t
    *                    (abApplyToWave func arg)                     *
    *  And finally, the function that does the work. You give it the  *
    *  name of a unary function (takes one argument) which works on   *
    * numbers, and then this is applied to all members of a waveform. *
    *                      Handles families too.                      *
    (defun abApplyToWave (func arg)
      (cond
        ((numberp arg) (funcall func arg))
        ((drIsDataVector arg) (vecMap 'abApplyToWave func arg))
        ((drIsWaveform arg)
         ; Create new waveform, but transfer units if not set on
         ; new waveform already. This ensures plotting on the same y-axis
         (let (new yVec)
           (setq new (wfMap 'abApplyToWave func arg))
           (setq yVec (drGetWaveformYVec new))
           (unless (getq yVec units)
             (putpropq yVec (getq (drGetWaveformYVec arg) units) units)
           new
        ((famIsFamily arg) (famMap 'abApplyToWave func arg))
        (t
          (error "abApplyToWave: can't apply %L to %L\n"
                 func arg)
