  3. cloning group
  • Subscribers 150
  • Views 19083
cloning group
howardhaoracle
howardhaoracle over 12 years ago
Hi.
How can I clone a group in layout?
I can create instance and place them at several places in layout. When I modify one instance, all other identical instances will change at the same time.. But I dont want to create instance, I'd like to use group instead and clone it ..
 Thanks for your help
Howard
    Howard,
    If using VLS XL you can do a "synchronous" copy (as an alternative to a synchronous clone) - this can create a copy of the original transistors and interconnect, and put both the original and copy into figGroups which are treated as synchronous - so an edit to one also edits the other.
  • howardhaoracle
    Hi Andrew;
    Thanks for the help.. How do I perform "synchronous" copy? I looked at all the pull-down window, I cant find the "synchronous" copy..
     Thanks again
    Howard
  • howardhaoracle
    Hi Andrew
    I forgot to mention that I am in VLS XL mode
    Howard
  • wschwab
    wschwab over 12 years ago
    Hi Howard,
    while in copy command type on F3 to get the copy options form.
    In the lower section of this form is the button for create synchronous copy.
    -Werner
  • howardhaoracle
    Thanks Werner...
    It worked!!! I love this forum
    Howard
