  3. How to use stimulus files as parameters in paramAnalysi...
  • Views 13465
How to use stimulus files as parameters in paramAnalysis
vanderpollator
vanderpollator over 12 years ago
If I have two stimulus files, AC_1.scs and AC_2.scs and I use "AC_stimulus" as a parameter.  How do I sweep these two stimulus files in paramAnalysis?    I know the following oceanscript will NOT work (But syntax is OK)
stimulusFile( ?xlate nil  strcat(pre_path design_name post_path  AC_stimulus) )
paramAnalysis("AC_stimulus" ?values '("AC_1.scs" "AC_2.scs" ) )
paramRun()
If this scheme of "ASCII inputs as values in paramAnalysis is not working", what I actually want is "How to place two simulation results on the same plot?"   (paramAnalysis should be the most convenient way to do it but I think it may have the other smart way to do it.)
    I don't think it's possible to do a parametric analysis of string names.
    You'd probably have to have a foreach loop, and change the stimulusFile each time - note that each call to stimulusFile() is cumulative (unless you re-initialize the OCEAN session by calling simulator() again), and you can't currently do delete('stimulusFile). See this solution of mine as an alternative.
    Within the loop, you can do your plotting - and then the plots can be on the same graph.
    Kind Regards,
