  3. how to remove repeat element in a list
  • Replies 13
  • Views 28147
tomchen
tomchen over 13 years ago
Hi
I want to remove repeated element that in a list, but I can't find the related function for this.
I try to use hash table to solve it , but the order of this list will be changed
does any other function for this ??
ex:
                                                      change to
aa= list("AA" "AA" "AA" "BB" "BB")  -----------------> aa = list("AA" "BB)
    Andrew Beckett over 12 years ago +1
    Jim, The downside of this implementation is that it is O(n^2) and whilst the list is in order, it's in the order of the last occurrence rather than first occurrence of a repeated value. An ordered version…
    Andrew Beckett over 7 years ago in reply to Dushyant
    Hi Dushyant,
    Yes, you'll find that implementation in an older post I made 7 years ago (I'm sure I've posted it elsewhere before that too). The implementation above specifically was to allow the resulting list to be in the same order as in the input list, whereas the approach you've shown and in my other post will list the values in an arbitrary order. If the order doesn't matter, then the ->? approach would be fine. However, the saving is relatively small since they're both O(N) rather than O(N^2) and in most practical implementations the difference would probably be dominated by something else in the overall application where this is used, I'd expect. Both use hash tables to gain performance here - they can be useful for this purpose - although are not always the saviour for efficiency as it depends on what you're doing...
  • Dushyant
    Dushyant over 7 years ago in reply to Andrew Beckett
    Ok -- I got so deep into speeding it up that I did not catch the ordering requirement in the question. Stuck out tongue
    Thanks for these solutions, though. They are really helpful!
    On a different note -- do you know if there are the likes of common lisp's functional programming features like reduce or Haskell's foldl, foldr? They are pretty useful for lisp processing, but I was not able to find them in SKILL.
    Dushyant
    There's a discussion (and example of foldr) in this thread. I haven't seen any formal requests for Common Lisp's reduce function to be implemented in SKILL.
