  3. Determine if file is member of co-managed set
  • Views 13527
Nellis
Nellis over 12 years ago
 I have a list of filenames from a Cadence library and I am looking for a way to determine if the file is a member of a co-managed set.
 I have a function that can determine the library, cell and view given a path, but I need to take it a step farther and determine if the file is a member of a co-managed set.
I am trying to write a report to determine if there any files in the library that are not part of a co-managed set.  This report will include files like cdsinfo.tag, data.dm and all of the files under the library.  I want to make sure they are all under GDM management.
 - Nellis
    Hi Nellis,
    ddGetCoManagedSet(ddGetObj("libName" "cellName" "viewName"))
    will give you a list of the filenames which are in the co-managed set for that lib/cell/view.
