  3. question about using dbCreateParamInst
  • Subscribers 150
  • Views 13994
JaneCA
JaneCA over 12 years ago
I am writing a pcell using dbOpenCellViewByType and dbCreateParamInst
When I tried to change parameters, it returned error "dbCreateparamInst: cellView is opened read-only."
When using the default values it works fine.
What's the problem of this?  Thank you.
  • meland
    meland over 12 years ago
     What's the command you are using for the dbOpenCellViewByType? From then info provided, it sounds like you opened in read-only mode instead of a writeable mode. This would be the last (fifth) entry into the command. I think you want append mode "a", but there are 9 you can choose from which are detailed in the documentation.
    cvdb=dbOpenCellViewByType("libName" "cellName" "viewName" nil "a")
     That being said, I'm not that familar with PCell creation, or the specific problem you are encountering.
    -Matt
    I thought I'd replied to this - but for some reason (maybe due to a bad connection) it didn't appear. Anyway, I was saying something similar to Matt - maybe your call is wrong - it's very hard to know what the issue is without seeing the code!
