  3. Skill Code for Automatic Pin Placement
  • Subscribers 150
  • Views 16459
imaneet
imaneet over 12 years ago
Can some help creating a skill code for automatic pin placement on devices/blocks?
In my case, i have a logic block which is already been done (pins are placed) but on the next heirarchy, the pins labels have changed. the skill routine should just place the new pins to the logic block instead of doing it manually again.
  • W Relyveld
    W Relyveld over 12 years ago
    I am doing this and have inserted the function below. But it is not directly usable: it is part of a collection of functions I use and needs a global parameter wrtop and another function to notify results (wrWindowName). You could modify the procedure to accept parameters or first define the global parameter, see below.
    After the pins are copied, the pin labels can be added with procedure wrAddLabels. It is also pasted below. I also requires some wrtop.xx values which are process dependent. I always try to create process independent procedures. I probably miss several things but if you want to invest some time I think you can get it working. Use what you need.
    Greetings, William
          setplist( 'wrtop nil)
          wrtop.Cell = geGetEditCellView( wrtop.Window)
          wrtop.LibName = wrtop.Cell->libName
          wrtop.DbType = dbGetDatabaseType()
          wrtop.CellName = wrtop.Cell->cellName
          wrtop.ViewName = wrtop.Cell->viewName
          wrtop.CellViewType = wrtop.Cell->cellViewType
          wrtop.CellViewMode = wrtop.Cell->mode  wrtop.StepMin = 0.01
    ;; process dependent: select pin/text
    wrtop.LabelPinType  = "pin"
    ;; The function:
    procedure( wrCopyPins( )
      let( ( wr instances)
        wr = ncons( nil)
        wr->Text = ""
        wr->Replaced = 0
        unless( rexMatchp( "layout" wrtop.ViewName)
          wr->Text = strcat( "skip non-layout view " wrtop.ViewName)
          wr->Error = t
        when( ! wr->Error && wrtop.CellViewMode == "r"
          wr->Text = "error: cell must be editable"
          wr->Error = t
        unless( wr->Error
          wr->SchCell = wrOpenCellViewByType( wrtop.LibName wrtop.CellName "schematic")
          unless( wr->SchCell
            wr->Text = "warning: schematic view not found"
            printf( wr->Text)
        unless( wr->Error
          instances = geGetSelectedSet( )
          instancepointer = car( instances)
        when( ! wr->Error && ! instancepointer
          wr->Text = "error: nothing selected, please select a single instance"
          wr->Error = t
        when( ! wr->Error && length( instances) > 1
          wr->Text = "error: selection contains more than one instance, please select a single instance"
          wr->Error = t
        when( ! wr->Error && instancepointer->objType != "inst"
          wr->Text = strcat( "error: " pcExprToString( instancepointer->objType) " selected, please select a single instance")
          wr->Error = t
        unless( wr->Error || ! wr->SchCell
          ;; get the schematic instance to be able to search the net names to which the instance terminals connect
          rexCompile( "|")
          wr->InstName = rexReplace( instancepointer->name "" 1)
          wr->SchInst = dbFindAnyInstByName( wr->SchCell wr->InstName)
        when( ! wr->Error && ! wr->SchInst
          printf( "%s: warning: did not find schematic instance %s\nwill not translate pins names." getCallingFunction( 0) instancepointer->name)
          wr->Text = "warning: pins not translated. "
        when( ! wr->Error && wr->SchInst
          wr->TerminalNames = wr->SchCell~>terminals~>name
          when( ! wr->Error && ! wr->TerminalNames
            wr->Text = "no terminals found"
            wr->Error = t
          ;; The schematic terminal names can contain <x:0> while the layout terminals are <y> type. Change both to <>.
          rexCompile( "<[0-9:]+>")
          wr->TerminalNamesFiltered = list( nil)
          foreach( term wr->TerminalNames
            wr->TerminalNamesFiltered = append1( wr->TerminalNamesFiltered rexReplace( term "<>" 1))
        unless( wr->Error
          when( wr->SchInst
            wr->ConList = mapcar( lambda( ( name) rexReplace( name "" 1)) wr->SchInst->conns~>name)
            wr->NetList = mapcar( lambda( ( name) rexReplace( name "" 1)) wr->SchInst->conns~>net~>name)
            wr->TranslateList = mapcar( lambda( ( con net) if( con != net list( con net))) wr->ConList wr->NetList)
            wr->TranslateList = setof( list wr->TranslateList list)
          geDeselectAll( )
          wr->BboxV = wrGetBBView( )
          wr->trans = geGetInstTransform( instancepointer)
          foreach( net instancepointer~>master~>nets
            wr->NewNetName = net~>name
            rexCompile( "<[0-9]+>")
            wr->OldNetNameBase = rexReplace( net~>name "" 1)
            rexCompile( ":$")
            wr->OldNetNameBase = rexReplace( wr->OldNetNameBase "" 1)
            wr->NewNetNameBase = cadr( assoc( wr->OldNetNameBase wr->TranslateList))
            if( wr->NewNetNameBase
            then
              rexCompile( wr->OldNetNameBase)
              wr->NewNetName = rexReplace( net~>name wr->NewNetNameBase 1)
            else
              wr->NewNetNameBase = wr->OldNetNameBase
            when( ! wr->SchInst || member( wr->NewNetNameBase wr->TerminalNamesFiltered) || member( strcat( wr->NewNetNameBase "<>") wr->TerminalNamesFiltered)
              ;; copy pins if it is also a pin at the current level
              wr->NewNet = dbFindNetByName( wrtop.Cell wr->NewNetName)
              unless( wr->NewNet wr->NewNet = dbCreateNet( wrtop.Cell wr->NewNetName))
              wr->term = net~>term
              wr->NewTerm = dbFindTermByName( wrtop.Cell wr->NewNetName)
              unless( wr->NewTerm
                wr->IOType = wr->term->direction
                unless( wr->IOType wr->IOType = "input")
                wr->NewTerm = dbCreateTerm( wr->NewNet wr->NewNetName wr->IOType)
              wr->Rect = nil
              foreach( pin wr->term~>pins
                when( pin->fig->bBox
                  wr->Bbox = dbTransformBBox( pin->fig->bBox wr->trans)
                  when(
                       leftEdge(  wr->Bbox) > leftEdge( wr->BboxV) &&
                       rightEdge( wr->Bbox) < rightEdge( wr->BboxV) &&
                       bottomEdge( wr->Bbox) > bottomEdge( wr->BboxV) &&
                       topEdge( wr->Bbox) < topEdge( wr->BboxV)
                       when( net->name != wr->NewNetName printf( "%s: connecting %s to %s\n" getCallingFunction( 0) net->name wr->NewNetName))
                     wr->RodName = sprintf( nil "pin_%s" wr->NewNetName)
                     ; wr->lpp = pin->fig->lpp
                     wr->lpp = list( car( pin->fig->lpp) "pin")
                     wr->Rod = rodGetObj( wr->RodName wrtop.Cell)
                     cond(
                       ( ! wr->Rod
                         ;; Create a rod object for the rect
                         wr->Rod = rodCreateRect( ?name wr->RodName ?layer wr->lpp ?bBox wr->Bbox ?cvId wrtop.Cell)
                         wr->Rect = wr->Rod->dbId
                       ( wr->Rod->dbId->bBox != wr->Bbox
                         wr->Rect = dbCreateRect( wrtop.Cell wr->lpp wr->Bbox)
                     when( wr->Rect
                       leAttachFig( wr->Rect instancepointer)
                       wr->newpin = dbCreatePin( wr->NewNet wr->Rect)
                       wr->newpin~>accessDir = pin~>accessDir
                       geSelectObject( wr->Rect)
                       wr->Replaced = wr->Replaced + 1
        ) ;; unless
        unless( wr->Error
          if( wr->Replaced == 0
          then
            wr->Text = "no pins copied"
          else
            wr->Text = strcat( wr->Text pcExprToString( wr->Replaced) " pins copied")
            wrtop.stick = t
        ) ;; unless
        stringp( wr->Text) && wrWindowName( sprintf( nil "%s%s%s: %s: %s" wrtop.MacroTxt wrtop.WriteModeTxt wrtop.DecodeBindKeysText getCallingFunction( 0) wr->Text))
        ! wr->Error
    procedure( wrAddLabels( )
        wr = ncons( nil)
        wr->Replaced = 0
          wr->Error = t
          wr->Error = t
        if( wrtop.Window
        then
        else
          instances = wrtop.Cell~>instances
          wr->BboxV = wrtop.Cell->bBox
        unless( instances
          geAddSelectBox( wrtop.Window t hiGetViewBBox( ))
          geDeselectAll( )
        sel = setof( shape instances shape~>objType == "rect" && ( shape~>purpose == "pin" || shape~>purpose == "lvstext"))
        when( ! wr->Error && ! sel
          wr->Text = "no pins found"
           wr->Error = t
        unless( wr->Error
          wr->BboxVx1 = leftEdge( wr->BboxV)
          wr->BboxVy1 = bottomEdge( wr->BboxV)
          wr->BboxVx2 = rightEdge( wr->BboxV)
          wr->BboxVy2 = topEdge( wr->BboxV)
          foreach( pin sel
            when( wr->Term = pin->net->term
              wr->PinName = pin->net->name
              wr->Bbox = pin->bBox
              wr->x1 = leftEdge( wr->Bbox)
              wr->y1 = bottomEdge( wr->Bbox)
              wr->x2 = rightEdge( wr->Bbox)
              wr->y2 = topEdge( wr->Bbox)
              wr->PointX = (wr->x1 + wr->x2)/2
              wr->PointY = (wr->y1 + wr->y2)/2
              wr->Point = list( wr->PointX wr->PointY)
              wr->Height = wr->y2 - wr->y1
              wr->Width  = wr->x2 - wr->x1
              if( min( abs( wr->PointY - wr->BboxVy1) abs( wr->PointY - wr->BboxVy2)) < min( abs( wr->PointX - wr->BboxVx1) abs( wr->PointX - wr->BboxVx2)) + 0.001
              then
                wr->LabelOrient = "R90"
                wr->LabelHeight = wr->Height / 2
              else
                wr->LabelOrient = "R0"
                wr->LabelHeight = wr->Width / 2
              cond(
               ( wr->LabelHeight < 0.2
                wr->LabelHeight = 0.2
               ( wr->LabelHeight > 22.0
                wr->LabelHeight = 22.0
              ;; BB: changed layer name reference for abcd3
              if( wrtop.Process == "abcd3"
              then
                wr->layerName = "text"
              else
                wr->layerName = pin->layerName
              unless( pin->children
                wr->Label = dbCreateTextDisplay( wr->Term wr->Term list( wr->layerName wrtop.LabelPinType) list( "font" "justify" "height" "orient" "drafting" "overbar" "origin" "visible") wr->Point "centerCenter" wr->LabelOrient "stick" wr->LabelHeight t nil t nil t "name" nil)
                wr->Label->parent = pin
                wr->RodName = sprintf( nil "pin_%s" wr->PinName)
                unless( rodGetObj( wr->RodName wrtop.Cell)
                  ;; Asign a rod name to the rect
                  rodNameShape( ?name wr->RodName ?shapeId pin ?permitRename t)
          ); foreach pin
          unless( wr->Error
            then
              wr->Text = "no corrections required"
            else
              wr->Text = strcat( pcExprToString( wr->Replaced) " labels created")
              when( integerp( wrtop.Applied)
                wrtop.Applied = wrtop.Applied + 1
        unless( stringp( wr->Text) wr->Text = "unknown error")
        unless( rexMatchp( wrtop.CellName wr->Text) wr->Text = sprintf( nil "%s, %s" wrtop.CellName wr->Text))
        ! wr->Error
    procedure( wrGetBBView( )
      let( ( wrPointList)
        wrPointList = list(
          geWindowToEditPoint( wrtop.Window car( hiGetViewBBox( hiGetCurrentWindow( ))))
          geWindowToEditPoint( wrtop.Window cadr( hiGetViewBBox( hiGetCurrentWindow( )))))
      list(
        min( caar( wrPointList) caadr( wrPointList)) : min( cadar( wrPointList) cadadr( wrPointList))
        max( caar( wrPointList) caadr( wrPointList)) : max( cadar( wrPointList) cadadr( wrPointList)))
    procedure( wrWindowName( text "t")
      let( ( wr)
        wr = ncons( nil)
        if( wrtop.stick
        then
          wrtop.stick = nil
        else
          foreach( window hiGetWindowList( )
            if( boundp( 'geIsGraphicalWindow)
            then
              geIsGraphicalWindow( window)
              hiChangeBannerLabel( window text 0)
            else
              wr->ViewName = geGetWindowRep( window)->viewName
              getWarn( )
              unless( wr->ViewName
                wr->ViewName = "empty"
              when( rexMatchp( "schematic" wr->ViewName) || rexMatchp( "layout" wr->ViewName) || rexMatchp( "symbol" wr->ViewName) || rexMatchp( "extracted" wr->ViewName)
          when( wrtop.LogFile
            fprintf( wrtop.LogFile "%s - %s\n" getCurrentTime( ) text)
            printf( "%s\n" text)
            sh( sprintf( nil "echo \"%s\"\n" text))
            when( rexMatchp( "error" text)
              sh( sprintf( nil "zsh -c \". ~/.zshrc; Background=on; FlowE '%s'\"" text))
  • imaneet
    Thanks, I like the line that says "Greetings William". Just to do test cases i would just say "hello" to be sure it's working.
    I will use whatever i can, thanks for the help.
