  3. Modified parameters don't change layout pcells
  • Replies 11
  • Subscribers 150
  • Views 11586
egolowen
egolowen over 12 years ago
I am writing SKILL code in order to modify the parameters of layout instances, however even though the parameter has been properly modified, the layout pcell does not change (for example, if I increase the length of an nfet the property is the correct value but the layout instance remains the same size).
 I have tried using:
  foreach(prop properties
prop~>value = param_value
and:
 dbReplaceProp(inst prop~>name 'string param_value)
But neither have fixed the issue.
Is there a better may to modify these parameters so the layout itself is updated properly? I was thinking of trying to use a replay file but that may not do the trick.
Elizabeth
    Anand,
    That was an example from a particular pcell I picked (I expect it was a transistor from gpdk045 or gpdk090 - I can't remember). Just because the device I picked had that parameter doesn't mean that you'd have the same parameter on a different device from a different technology. The parameters are specific to exactly how each pcell has been implemented - what they are called and what they control is up to whoever it was that implemented the pcell!
