  3. skill code to get details from schematic
  • Views 18106
Skill User
Skill User over 12 years ago
 Hello
For an example I have 1 capacitor connected with 2 pins and 2 nets in schematic. Now I want to read these details and dump into some file with its library name, cell name and view name.
Information could be instance name, nets name, pins name etc...
Someone please help me with some script so that I can understand and start working on that.
Regards
Varun
    Why do you keep asking the same vague questions over and over again, despite being asked to be more specific?
    I gave an answer (albeit vague, because the question was vague) in this previous thread of yours. And in this one.
    Kindest Regards,
  • skillUser
    skillUser over 12 years ago
    Hi Varun,
    Here is a simple example of some SKILL that outputs some details to
    the CIW (not to a file, though you can modify the code to open a port
    and then use fprintf in place of printf to output to that file, and then
    use close() on the file handle).
    * DISCLAIMER: This code is provided for Cadence customers to use      *
    * with Cadence tools at their own risk. The code may require          *
    * modification to satisfy the requirements of any user. The code and  *
    * any modifications to the code may not be compatible with current or *
    * future versions of Cadence products.                                *
    * THE CODE IS PROVIDED "AS IS" AND WITH NO WARRANTIES, INCLUDING      *
    * WITHOUT LIMITATION ANY EXPRESS OR IMPLIED WARRANTIES OF             *
    * MERCHANTABILITY, FITNESS FOR A PARTICULAR USE OR NON-INFRINGEMENT.  *
    * (c) 2013 Cadence Design Systems, Inc. All rights reserved.          *
    procedure(CCFprintSomeInfo(@optional (obj geGetEditCellView()) "d")
      if(obj~>objType=="cellView" then
        when(obj~>instances
          printf("CCFprintSomeInfo: cellview %s %s %s has instances:\n"
    	obj~>libName obj~>cellName obj~>viewName)
          foreach(inst obj~>instances
    	if(inst~>purpose=="pin"
    	  printf("Pin type %s, net:%s, term:%s\n"
    	    inst~>cellName inst~>net~>name inst~>pin~>term~>name)
    	  printf("Instance %s: terminals %L connected to %L\n"
    	    inst~>name inst~>instTerms~>name inst~>instTerms~>net~>name)
          ); foreach
          t
        ); when
      else
        printf(strcat("CCFprintSomeInfo: object of type %s\n"
          "  in cellview %s %s %s has attributes:\n%L") obj~>objType
          obj~>cellView~>libName obj~>cellView~>cellName obj~>cellView~>viewName
          obj~>??)
      ); if
    ); procedure CCFprintSomeInfo
    Hopefully this will help you to get started?,
    Lawrence.
    CCFprintSomeInfo.il
  • Skill User
    Thanks Lawrence for this script. It really helps me to get a start. I dumped some information in a file. I harcoded some syntax of XML using fprintf statements. Please let me know is that posible to dump in XML file format directly using some function or something else?
     Please share some information or procedure with an example if possible.
     Regards
    Varun
    Varun,
    See this post which discusses writing (and reading) XML.
