  3. Custom SKILL Code for Setting All Layers Valid in Layout...
  • Subscribers 150
  • Views 14394
Custom SKILL Code for Setting All Layers Valid in Layout XL
Anandaroop
Anandaroop over 12 years ago
I am new to SKILL programming and looking for suggestions on a code to set all layers valid in the Layer Select Window automatically when a layout  instance is invoked for the first time after starting virtuoso.
  • Matth83
    Matth83 over 12 years ago
    Hi Anand,
    You can use leSetAllLayerVisible(t) loaded from a script or from your .cdsinit in your rundir/.
    If you wish to load only certain layers, you can modify the rundir/.cadence/dfII/layerSets/techno/default.layersSet text file (if this is for several users, the best would be to link it from a seperate dir).
    Matthieu
    • Vote Up -1 Vote Down
