  3. How to get Transform data of elements within a Mosaic
  • Views 15567
RonSill
RonSill over 12 years ago
I am using  dbGetTrueOverlaps to extract data under my cursor through all levels of hierarchy. Ultimately I am striving to get the closest vertex of a path embeded down in the hierarchy to my current (top level) cursor location. I have no problem getting this resolved through all levels of hierarchy with one exception, Mosaics. I currently use dbGetHierPathTransform to transform the data up to my top level but if the elements are within a Mosaic then it always transforms the element data to be where it exists within the original (column 1 row 1) array instance. So if, for example, my cursor is over a path within row 2 column 5  instance of the array I do not get the location I need. It always returns col 1 row 1 equivalent. Is there some way to use  dbGetHierPathTransform to get accurate mosiac data specific to the instance location within the array? Or am I going to have to just do the math and multiply the offsets by the number of rows and columns?
Ron
  • dmay
    dmay over 12 years ago
    Are you using the last argument of dbGetTrueOverlaps which optionally returns the row/column information of overlaps in a mosaic? By default, the row/column information is not returned, so you must set the last argument to t. dbGetHierPathTransform is a relatively new function (not available in 5.1.41), so I have never used it before. I had to write my own code to parse the dbGetTrueOverlaps and do the mosaic transformation. Let me know if the row/col information does the trick and I'll update my code to use this new dbGetHierPathTransform. It would be much simpler.
    dbGetTrueOverlaps(
    d_cellView
    l_bBox
    [ l_layerPurposePair ]
    [ lx_level ]
    [ g_doRowCol ]
    => ld_fig | nil
    Derek
  • RonSill
     Early look at this looks promising, but I've been pulled onto something else for a bit so will let you know more when I get back onto this but it looks like the row column set to t is getting me just what I need. Thanks!
  • RonSill
     This did the trick! Worked perfectly for what I needed. Thanks again!
    Ron
