  3. Block execution in SKILL file while a form is on the sc...
  • Replies 12
  • Subscribers 150
  • Views 22688
Block execution in SKILL file while a form is on the screen
HTC060
HTC060 over 12 years ago
Dear SKILL experts
I tried to write a SKILL function that shows a form created by hiCreateAppForm() on the screen and blocks execution until the form is removed from the screen by the user with a OK or Cancel.
In the form I have a listBoxField. The user selects ONE item in the listBox. When OK is pressed the SKILL function that showed the form returns the selected item, when Cancel was selected the function returns nil.
I tried the argument: ?dialogStyle 'modal but the form does not block the execution.
The code is in one SKILL file that I load but the execution of the SKILL statements in the file is not blocked while the form is on the screen.
Here is the code:
file listBox.il:
      ; Create the application form
      hiCreateAppForm(
        ?name 'VARselectListForm
        ?formTitle "Title"
        ?dialogStyle 'modal
        ?initialSize t
        ?buttonLayout 'OKCancel
        ?fields list(
          list(
            hiCreateListBoxField(
                ?name 'VARselectListFormListBox
                ?choices nil
                ?value nil
                ?prompt "Nodes"
            ) ; hiCreateListBoxField
            list(0 0)
            list(150 400)
            50
          ) ; list
        ) ; list
      ) ; hiCreateAppForm
 procedure(SHOWselectListBoxForm(title choices)
    when(and(boundp('VARselectListForm)
             hiIsForm(VARselectListForm))
        VARselectListForm->title = title
        VARselectListForm->VARselectListFormListBox->choices=choices
        hiDisplayForm(VARselectListForm)
        VARselectListForm->VARselectListFormListBox->value
    ) ; when
) ; SHOWselectListBoxForm
And the the file that uses this:
load("listBox.il")
choices = '("aaa" "bbb" "ccc" "ddd" "eee")
title   = "Form title"
printf("Before the box\n")
choice = SHOWselectListBoxForm(title choices)
printf("After the box: %L\n" choice)
The message After the box............. already appears while the form is on the screen.
I want a blocking solution. The dialog style systemModal is gone.
 Of course I can make a wait loop with global variables, but is there a better way?
Hans Kok
    Hi Giuseppe,
    Unfortunately dialog boxes are not forms, so hiFormList() doesn't work. There doesn't appear to be an equivalent for dialog boxes.
    I just wrote something that finds the symbol for any dialog boxes which match a pattern. Because this relies on some internal information that I don't want to make public in the forums, it's password encrypted. You can use it however:
    load("abFindMatchingDBox.ile" "dbox")
    If all your dialog boxes are generated with gensym('myBox) then you could use:
      abFindMatchingDBox("^myBox")  ; pass a regular expression.
    Note that any dialog boxes which have been closed won't show up - because the variables get set back to nil. So you could then close them by doing:
      foreach(dbox  abFindMatchingDBox("^myBox") hiDBoxOK(symeval(dbox)))
    or similar.
    Hope that helps!
    abFindMatchingBBox.tar.gz
  • GiuseppeGreco
    GiuseppeGreco over 12 years ago
    Thank you Andrew! Very useful!
