  3. how to use skill to do corner rounding for intersected ...
  • Subscribers 150
  • Views 17607
how to use skill to do corner rounding for intersected paths
richardyuan
richardyuan over 12 years ago
I'm a skill-language beginner.
I created lots of poly lines using dbCreatePath. These lines intersected each other and forms right anlge or accute angle at the intersection.
I need to get corner rounding effect at the intersections. Can anybody help me?
    Not obvious what you actually want it to do. Maybe uploading some pictures of before and after would help. Use the Options tab when replying to posts to upload pictures.
    Have you looked at using Edit->Advanced->Modify Corner to see if that does what  you want? You may need to convert the shapes to polygons first before using this.
  • richardyuan
     Thanks for your reply.
    I think the pattern is hard to realise by pologons as there're too many lines. The attached file is the schematic diagram.
    If I convert all the paths to polygons, can it recognize the intersections as I marked?
  • richardyuan
    Here is the final pattern I need after corner rounding.
    Try this code as a starting point. The general algorithm that I used was:
    1. Classify paths as vertical or horizontal (the code only works for paths, and only single-segment paths; it's an exercise for you if you need it more general)
    2. Find the intersections of these two sets of paths
    3. Record all the vertices of the intersections
    4. Grow the intersections by twice the radius (to allow some margin and then AND with the original shapes to generate a cross polygon at each intersection.
    5. Modify all the corners that were identified in step 3 to be rounded (or chamfered)
    6. Optionally merge with the original shapes (or leave as additional shapes on top).
    Here's the code:
    /* CCFroundInternalCorners.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Nov 28, 2013
    Modified
    By
    Example of rounding corners at intersections in a lattice structure.
    Can be used this way:
    shapes=CCFbuildStripes(?layer "Metal2" ?width 0.3 ?spacing 1.0 ?rows 5 ?columns 5)
    CCFroundInternalCorners(?shapes shapes ?distance 0.1)
    or:
    CCFroundInternalCorners(?shapes shapes ?distance 0.1 ?merge t)
    SCCS Info: @(#) CCFroundInternalCorners.il 11/28/13.13:09:05 1.1
    *      CCFbuildStripes([?cv geGetEditCellView()] [?layer "Metal1"]      *
    *          [?width 0.2] [?spacing 1.5] [?rows 5] [?columns 4])          *
    *    Function to build some test data for the function below. Allows    *
    * control over the layer used and width and spacing and number of paths *
    *                            in the lattice.                            *
    procedure(CCFbuildStripes(@key (cv geGetEditCellView()) (layer "Metal1")
            (width 0.2) (spacing 1.5) (rows 5) (columns 4))
        let((horizLength vertLength shapes ord)
            horizLength=(width+spacing)*columns+spacing
            vertLength=(width+spacing)*rows+spacing
            for(n 0 rows-1
                ord=(width+spacing)*n+width/2.0+spacing
                shapes=cons(dbCreatePath(cv layer list(0:ord horizLength:ord) width) shapes)
            for(n 0 columns-1
                shapes=cons(dbCreatePath(cv layer list(ord:0 ord:vertLength) width) shapes)
            shapes
    * CCFroundInternalCorners([?shapes geGetSelSet()] [?tempLayer "y1"] [?chamfer nil] *
    *       [?distance 0.05] [?sides 20] [?outputLayer layerName] [?merge nil])        *
    *  Takes a bunch of horizontal and vertical paths, and then adds rounded corners   *
    *   at the intersections. Keyword arguments are added to allow control over the    *
    * list of shapes to work on (defaults to the selected set), whether to chamfer or  *
    *   round (default) the corners. The radius used for rounding or chamfering, how   *
    *   many sides to use in rounded corners. It also allows the output layer to be    *
    *    chosen (defaults to the layer of the first shape). By default the rounded     *
    *   crossovers are produced in addition, but with ?merge t it can merge all the    *
    *                                 shapes together.                                 *
    procedure(CCFroundInternalCorners(@key (shapes geGetSelSet()) (tempLayer "y1") chamfer
            (distance 0.05) (sides 20) outputLayer merge)
        let((cv horizontal vertical vertexTable intersections points
                grown crosses selVertexList new)
            unless(shapes error("No shapes provided\n"))
            unless(outputLayer outputLayer=car(shapes)~>layerName)
            cv=car(shapes)~>cellView
            ; Split the shapes into horizontal and vertical paths
            ; (rather simplistic and with no error checking!)
            foreach(shape shapes
                if(shape~>objType=="path" && shape~>nPoints==2 &&
                    xCoord(car(shape~>points))==xCoord(cadr(shape~>points)) then
                    vertical=cons(shape vertical)
                else
                    horizontal=cons(shape horizontal)
            ; By anding the horizontal and vertical, can find the intersections.
            ; Record the coordinates of all the intersection shapes for later use
            intersections=dbLayerAnd(cv tempLayer vertical horizontal)
            vertexTable=makeTable('vertexTable nil)
            foreach(shape intersections
                points=
                    if(shape~>objType=="rect" then
                        ; this is in IC615 onwards
                        destructuringBind(((llx lly) (urx ury)) shape~>bBox list(llx:lly llx:ury urx:ury urx:lly))
                    else
                        shape~>points
                foreach(point points
                    vertexTable[point]=t
            ; originally tried merging all the layers and then using leModifyCorner - but the
            ; problem was that the "holes" in the lattice structure meant that some of the
            ; dividing lines meant that the modified corners ended up being rounded in the wrong
            ; direction, and some got omitted altogether. So instead, generate "crosses" by
            ; anding the grown intersections with the original shapes
            grown=dbLayerSize(cv tempLayer intersections distance*2)
            crosses=dbLayerAnd(cv outputLayer grown shapes)
                dbDeleteObject(shape)
            foreach(shape grown
            ; Now modify the corners for the corners which we identified as "internal"
            ; corners in the lattice
            foreach(shape crosses
                selVertexList=foreach(mapcar point shape~>points
                    vertexTable[point]
                leModifyCorner(shape selVertexList chamfer distance sides)
            ; Optionally merge the shapes. Always return the generated objects
            ; though
            if(merge then
                new=dbLayerOr(cv outputLayer shapes crosses)
                new
            else
                crosses
    The picture below is the result of doing:
    CCFroundInternalCorners(?shapes shapes ?distance 0.1 ?outputLayer "Metal3")
    I zoomed in to show the rounding, and intentionally output the cross-shapes on a different layer to make them stand out; most likely you'd omit the ?outputLayer argument, and possibly pass ?merge t instead.
    Kind Regards,
  • richardyuan
    Thank you Andrew. I got your idea in releasing the corner rounding. But it's hard for me now to understand all your skill statements. It will take some days. As you can see, the question I post is very general. In our MEMS application, we need to do corner rounding for the intersections or turn corners of lines in any angle, or of lines and plates(circular). Hope the algorithm can all work well.
