  3. How to get reference to selected instance pin
  • Views 14004
azde
azde over 12 years ago
If you select an instance in your schematic, you can get a reference to it using geGetSelSet().
I find this doesn't work if the selected object is an instance pin.
My ultimate goal is to create a bindkey to name add a wire label for the wire connected to these pins and make the lable name equal to the pin name. This will save me some drudgery in the future. Too often I'm plotting signals with random names like net0153 because I didn't have the patience to name every net in my testbench.
So if anyone knows a way to get db refernces to these objects, please share.
Thanks!
  • azde
    Actually,
     Solution ID: 11353388 mentions a new feature that obviates this..
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1ZkoIwFEXXwgpeAi0hn4AMYVQaI_BDIaiFCHEqUFbfuIA-9_PUrQMFLBuqsT1Xr1YM1RUyKNQSy46J_R9EYzPSENPUyE-4hRZg_32oJfoHHUEOBfl6WcYaoo6dGoiZPvM0osjIV4EP4tEvpRQytx6DdadPlrVO0vftsgnz0561lFzFLO42c0u6OThlbGwjh3ull031M04q-_H5xXWD3V4p8qexyvnrGBy4_bZ8UVe4KTxyxvdQGQmJuhOms7kjF_oxcRJO2z5kQYN7neqSBJEr-iPcumG2NV36A2cmiUg!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
