  3. Convert rectilinear polygon to rectangles
  • Replies 8
  • Subscribers 150
  • Views 20209
PietroUser
PietroUser over 11 years ago
I have a rectilinear polygon (all the angles are multiples of 90 degree) and I would like to divide the shape in rectangles.
I used dbLayerTile() but the result is a division in only vertical rectangles. I would like to divide in vertical and horizontal rectangles.
Attached is an example.
Pietro
  • girig
    girig over 11 years ago
     Hi Pietro,
     One solution would be to slice/tile vertically once, with the same shape horizontally tile one more time (refer to http://support.cadence.com/wps/mypoc/cos?uri=deeplinkmin:ViewSolution;solutionNumber=11656460).  And then "and" the two
    Giri.
  • marcelpreda
    marcelpreda over 11 years ago
     Hi Pietro,
     Not sure what means "vertical and horizontal rectangles".
    On a polygon like in attach what will be the result?
    BR,
    Marcel
  • skillUser
    skillUser over 11 years ago
    Hi Pietro,
    Since dbLayerTile() only fractures vertically, you can rotate the original shape and use dbLayerTile() and then rotate the result and the original back into place if you want to fracture horizontally.  If you want to fracture in both directions something like the following might be what you are looking for?
    procedure(CCSdoubleFracture(shape "d")
      let( (cv tiles rottiles newtiles)
        ;; fracture the shape into tiles
        tiles = dbLayerTile(cv=shape~>cellView list("y0" "drawing") list(shape))
        ;; rotate the shape through 90 degrees and re-fracture into tiles
        dbMoveFig(shape cv list(0:0 "R90"))
        rottiles = dbLayerTile(cv list("y1" "drawing") list(shape))
        ;; rotate the shape and the rotated tiles back into the original
        ;; shape orientation
        foreach(shape append(rottiles list(shape))
          dbMoveFig(shape cv list(0:0 "R270"))
        ); foreach
        newtiles = CCSrefractureAndJoin(tiles rottiles)
        ;; put all the tiles into a list
        nconc(tiles rottiles newtiles)
      ); let
    ); procedure CCSdoubleFracture
    Hope this helps!
    Lawrence.
  • shazzy
    shazzy over 11 years ago
    Hi Pietro
    I was facing the same issue some time back
    After analysing the problem I got to know that even though the shape is looking like a polygon on screen but the objType of the metal is coming out to be a PathSeg
    And performing dbLayerTile() on pathSeg only creates vertical rectangles.
    From there on I started using only paths and rects to draw the metals ( by changing the option in the bindkey tab )
    If you want you too can do the same.
    Huh? dbLayerTile() works fine with pathSegs (as far as I can see). I can't see any justification for drawing everything with paths because of some problem with dbLayerTile - what is that problem? After all, you could always call dbConvertPathSegToPolygon first if it really was an issue.
  • mcguyton
    mcguyton over 6 years ago in reply to skillUser
    Where do I find the code for CCSrefractureAndJoin?
    Andrew Beckett over 6 years ago in reply to mcguyton
    I can't find this function anywhere (I did some searching). It may have been in Lawrence's user area when he worked for Cadence. Maybe Lawrence can remember what it did?
  • skillUser
    skillUser over 6 years ago in reply to Andrew Beckett
    I can't find any reference to a function called CCSrefractureAndJoin (or CCFrefractureAndJoin, just in case it was written for the Forum with the CCF prefix) apart from in this thread, sorry.
