  3. Is there a function for mathematics constant PI?
  • Replies 13
  • Subscribers 150
  • Views 36079
richardyuan
richardyuan over 12 years ago
what's the expression for π in cadence skill?
  • ebecheto
    ebecheto over 12 years ago +1
    I usually use: pi=acos(-1);=> 3.141593 Someone has a better idea ?
    Andrew Beckett over 12 years ago +1
    defMathConstants() is what you want: > defMathConstants('MyConsts) MyConsts > MyConsts.? (SHRT_MAX SHRT_MIN INT_MAX INT_MIN DBL_MAX DBL_MIN E LOG2E LOG10E LN2 LN10 PI PI_OVER_2 PI_OVER_4 ONE_OVER_PI TWO_OVER_PI…
  • tweeks
    tweeks over 12 years ago +1
    BTW, if SKILL had defconst, I would totally use it. Many of my programs begin this way: (alias defconst defvar) (defconst pi 22/7.) ;; good enough for ancient Egypt
  • tweeks
    Thanks for the insights, Andrew.  From your explanation, I can see why the GDM API works as it does.  It sounds like, from a C programmer's point of view, it seems quite natural.
    I'm very curious as to the history of defMathConstants.  In Common Lisp and Emacs Lisp, those constants are simply bound to the value slots of certain symbols: pi, most-positive-fixnum, etc.  I couldn't find any mention of math constants in my Franz Lisp literature, so it seems to be something added by the SKILL developers, but I would like to know why they chose to use symbol property lists over the usual Common Lisp and Emacs Lisp conventions.  Maybe since the math constants ultimately are from C's math.h, it was easier to expose them to SKILL through property lists than by binding individual variables?
    Unfortunately I'm unable to offer much more than speculation. Looking at a comment in the source code, there's a PCR number reference (the predecessor to our current CCR system for tracking changes). The number is low enough that it would have been before I joined Cadence, and at a rough guess about 20 years ago. It's not from the era of the early days of SKILL (late 1980's) but more like 1994. None of the people involved in developing SKILL then are still around, and the PCR system no longer exists so I can't find out the history.
    I suspect that it was a pragmatic decision at the time based on requests from users/R&D, rather than looking around to see what other LISP implementations did.
  • tweeks
    Thanks Andrew.
    I should start a new thread about SKILL's history.  :)  There's a lot of interesting stuff there.  For example,
    • It is documented that SKILL was based on Franz Lisp.  Franz Lisp, in turn, was based on a PDP-11 Lisp which seems to have been originally written by none other than Richard Stallman while he was a freshman at Harvard!  (See section 1.1 here and paragraph 2 here.)  Some of the distinguished builtins in SKILL, like getd and putd (not found in CL or Emacs Lisp), were inherited from this Harvard PDP-11 Lisp.
    • Franz Lisp was developed at Berkeley, and its documentation continues the musical theme, being divided into four "movements" with traditional Italian tempos: "allegro non troppo", "largo".  The final movement is "allegro", which later became the name of Franz Lisp Inc's Common Lisp implementation.  Can we assume the names "Cadence", "Virtuoso", "Composer", etc. are continuations of the Franz theme?
    • Franz Lisp seems to be where the idea of "type template characters", like "l" for list and "x" for fixnum, came from, though SKILL added the idea of specifying them in the definition of a procedure.  (In Franz, they were only used in the documentation.)  Franz Lisp had a few features SKILL does not, like a low-level type called a "hunk", and support for bignums (arbitrarily large integers).  Franz also had support for reader macros strong enough to implement infix operators, which may be how they are done in SKILL today, though the user API for creating reader macros has apparently been hidden to prevent chaos. :)
    • Franz Lisp had an excellent debugger called "FIXIT" which SKILL has largely retained.
    You must know a lot about the history of SKILL, Andrew.  Please share! :D
