  3. How to do a plot in Cadence?
  • Replies 23
  • Subscribers 150
  • Views 36330
Alex Liao
Alex Liao over 12 years ago
Hi, everytime when I want to print a schematic/ layout view to a file, it always says:
There were no system .cdsplotinit files found.
*WARNING* Plotter configuration not loaded.
 I could not find it in the provided PDK. Instead, I found something interesting. Under the /CMC/tools/cadence/IC5141USR6_lnx86, I found a cdsplotinit (no dot in front) and under /CMC/tools/cadence/IC5141USR6_lnx86/tools.lnx86/plot/samples, I found a cdsplotinit.sample.
 I am sure thoses are something related to the plot function. However I tried to rename them to .cdsplotinit which is required from the warning message and it is still not working. Not a proper plotter can be found.
Anyone got an idea?
Alex
  • bid75
    bid75 over 7 years ago in reply to Alex Liao
    No answer to this question - "Color plot settings to print layout in pdf". Can someone pls help?
    Bhavin
  • mbracht
    mbracht over 7 years ago in reply to bid75
    Hi Alex,
    This discussion is getting a little off topic. Your original question was about an error due to a missing .cdsplotinit - it did not say anything about "Color plot settings to print layout in pdf". So I would say according to the guidelines of this forum this is a typical case for either opening a new thread or just file a case at Cadence customer support.
    Moreover - did you read the documentation Andrew has been  pointing you at several times? It answers most of your question.
    regards
    Max
  • mbracht
    mbracht over 7 years ago in reply to mbracht
    Sorry for mistakenly addressing this to Alex - it was of course meant to be for Bhavin.
    Sorry Alex!
    Max
