  3. Cadence 5.1.41 & 6.1.5 supported platform
  • Views 1746
Duy Hien
Duy Hien over 10 years ago
Hi everyone,
I would like to install Cadence IC 5.1.41 and IC 6.1.5 in the same platform. The following link shows that I should install in Linux RHEL 4. However, it seems that the hardware of my computer does not support for RHEL 4 any more. Have you install Cadence IC 5.1.41 in RHEL 5 before? Any suggestion is really appreciated. Thank in advanced.
www.cadence.com/.../Supported_Platforms_Matrix.pdf
    Whilst IC5141 is not supported on RHEL5, in practice it runs OK. It's somewhat irrelevant whether it is supported or not because it is past the end-of-support date anyway (the last hotfix was in November 2011). I've been running IC5141 on RHEL5/6 for the last 7 years...
    One thing that doesn't work is cdsdoc. I wrote a solution which describes how to modify things so that it can be made to work.
    Kind Regards,
