  3. Getting coordinates for pin placement
  • Replies 15
  • Views 26432
LongTimeNovice
LongTimeNovice over 11 years ago
Hello, everyone.  I'm trying to examine a pin that's in a layout subcell, and then draw a pin directly over it.  I'm having trouble getting my coordinates in the correct format.  I'm sure of two things: 1) I'm probably making this harder than it needs to be, and 2) I'm probably missing something obvious.  I've pasted the code, and below that is the response from Cadence.
############# Here is my code #############
;GET bBox OF PIN IN TARGET INSTANCE
pBox=car(instTerm~>term~>pins)~>fig~>bBox
;SEPARATE OUT LOWER LEFT COORDINATES
pBoxLL=car(car(pBox))
pBoxFixLL=dbTransformPoint(pBoxLL inst~>transform)
;GET LOWER COORDINATE AND CONVERT TO STRING
pBoxFixLower=car(pBoxFixLL)
sprintf(pBoxFixLower "%L" pBoxFixLower)
;GET LEFT COORDINATE AND CONVERT TO STRING
pBoxFixLeft=cdr(pBoxFixLL)
sprintf(pBoxFixLeft "%L" pBoxFixLeft)
pBoxFixLeft = substring(pBoxFixLeft 2 strlen(pBoxFixLeft)-2)
;MAKE A STRING WITH LOWER AND THEN A COLON AND THEN LEFT
pinCoordsLL=strcat(pBoxFixLower ":" pBoxFixLeft)
;SEPARATE OUT UPPER RIGHT COORDINATES
pBoxUR= cdr(car(pBox))
pBoxUR=car(pBoxUR)
pBoxFixUR=dbTransformPoint(pBoxUR inst~>transform)
;GET UPPER COORDINATE AND CONVERT TO STRING
pBoxFixUpper=car(pBoxFixUR)
sprintf(pBoxFixUpper "%L" pBoxFixUpper)
;GET RIGHT COORDINATE AND CONVERT TO STRING
pBoxFixRight=cdr(pBoxFixUR)
sprintf(pBoxFixRight "%L" pBoxFixRight)
pBoxFixRight = substring(pBoxFixRight 2 strlen(pBoxFixRight)-2)
;MAKE A STRING WITH UPPER AND THEN A COLON AND THEN RIGHT
pinCoordsUR=strcat(pBoxFixUpper ":" pBoxFixRight)
;MAKE STRING WITH UPPER-LEFT COORDS AND LOWER-RIGHT COORDS SEPARATED BY A "/"
pinCoords=strcat(pinCoordsLL "/" pinCoordsUR)
;CONVERT THIS STRING TO A LIST CONTAINING L:L AND U:R
pinCoords = parseString(pinCoords "/")
;PRINT THESE VARIABLES FOR DEBUGGING PURPOSES
printf("  *** pinCoordsLL is %A\n" pinCoordsLL)
printf("  *** PinCoordsUR is %A\n" pinCoordsUR)
printf("  *** PinCoords is %A\n" pinCoords)
;MAKE A PIN USING pinCoords VARIABLE
leCreatePin( cv  pLPP  "rectangle"  pinCoords  pName  "inputOutput"  list("left" "right" "top" "bottom") )
############# This is the response from Cadence starting with the debugging lines and ending with the error #############
*** pinCoordsLL is "11.175:10.315"
*** PinCoordsUR is "11.605:10.745"
*** PinCoords is ("11.175:10.315" "11.605:10.745")
*Error* length: argument must be a list or an array - "11.175:10.315"
<<< Stack Trace >>>
leCreatePin(cv pLPP "rectangle" pinCoords pName ... )
I notice that the PinCoords list, when printed, looks right but has quotes in it.  I wonder if this throwing off my leCreatePin statement.
I'd love to hear your thoughts.
Thank you!
Steven.
  • LongTimeNovice
    Ok, now I see that my previous post appears twice in this thread. I'm sorry for the confusion! If there's a moderator reading this, please feel free to delete one of the duplicated posts. Thank you!
    Stephen,
    Your code is a little strange - the foreach loop has a loop variable called instTerm, but it's actually going to be a list of pins. That's because:
    instPinList=inst~>instTerms~>term~>pins
    will be a list of lists (one list per inst term, and then an inner list which is one per pin).
    Then your pinFig assignment will start from the list of pins, and for each it will get the terminal and then back to all the pins again. This will be a list of lists of pins, and then when you take the car, it will be a list of pins - and for each you're getting the fig. So you have a list of figs. Then when you get th e bBox, you've got a list of bBoxes, which is your problem.
    I think you want:
    instTermList=inst~>instTerms
    and then:
    foreach(instTerm instTermList
    and then the rest of the code should be OK.
  • LongTimeNovice
    Hi, Andrew. Thank you! I had found my problem already, and I tried to describe it a few posts above this one, but you did a much better job explaining my issue concisely and clearly. And renaming my variable instPinList to instTermList is a really good improvement that will make my code more understandable in the future. I'll make that change in my script. Thank you!
    All your posts were being moderated (not sure why) - I think I've addressed that (I'm the moderator). So I was having to approve each one.
  • LongTimeNovice
    Thank you, Andrew. Yes, they had never been moderated in the past. Thank you for fixing that. Have a great day.
