  3. Net Tracing - Skill
  • Replies 23
  • Views 18281
Net Tracing - Skill
archive over 19 years ago
Hello All ,
I have a script which I use to calculate a particular net's  Net Length, total net resistance, Capacitance (w.r.t ground).
But the drawback is that I have to select the entire Net before invoking the "NetLength" Function.
So I want a script which can trace the entire net and give a list of metals, vias, instances that
belong to this net. i.e I will select any one metal/instance/via  of a net and the code should trace the entire net and give me the desired o/p.
NOTE: Instances here refer to instances/mosaics of vias.
Sathya
Originally posted in cdnusers.org by rimser9
  • Jay Bharti
    Jay Bharti over 11 years ago
    The version is IC6.1.6.101 .
    Jay
    That's getting a bit old - that's the base version of IC616 - but I just tried it there and it works fine for me too.
    Perhaps you'll need to contact customer support so that an AE can look at this with you?
  • Jay Bharti
    I contacted customer support for the mentioned issue between "leHiMarkNet" and "leMarkNet". This bug has been solved in the cadence release IC6.1.6_ISR13.
    Jay
