  3. rename net via skill?
  • Replies 14
  • Subscribers 152
  • Views 25168
danmc91
danmc91 over 10 years ago
Is there a convenient way in skill to rename a net?  For example:
mynets=setof(x cv~>nets x~>name=="VDD!")
foreach(net mynets
  the_missing_rename_net_function(net "VDD")  ;; is there such a function?
-Dan
  • Quek
    Quek over 10 years ago
    Hi Dan
    I have filed a request to move dbRenameNet to from "Cellview Input/Output Database Access Functions" section of $CDSHOME/doc/skdfref/skdfref.pdf to "Connectivity Creation and Modifications Functions" section. This will be done in IC617-500-3.
    Thank you very much for your feedback.
    Best regards
    Quek
  • danmc91
    Thanks!
  • PrasadAMSEng
    PrasadAMSEng over 7 years ago in reply to Andrew Beckett
    When I used dbRenameNet() command , it renames the net but after check-and-save it's name  got reverted. I tried schCheck() command also. If the process of changing the net name is to by changing the label/pin , then what is the use of dbRenameNet() command ? please give some example.
    Prasad
    Andrew Beckett over 7 years ago in reply to PrasadAMSEng
    Hi Prasad,
    The function is useful if you are modifying the connectivity in a database that is not going to be checked-and-saved. That might be a database with connectivity but no physical wiring, which is perfectly possible to create. Sometimes this is done for automatically generated views, or extracted views, or within a schematic pcell (where you can't run schCheck because schCheck is not a pcell-safe function). It could also be connectivity in a layout view.
    If however you're modifying a schematic which is going to be checked-and-saved, you need to remember that the connectivity is derived by the schematic extractor and it starts from the pins and labels attached to wires - the wires are physical representation, and then the schematic extractor creates the nets and names them appropriately based on the physical drawing.
