  3. Hierarchically Layer generation
  • Replies 12
  • Subscribers 150
  • Views 20282
stalapatra
stalapatra over 10 years ago
I am using the script CCShierLayerOpsSel.il for Layer generation, and it is working absolutely fine, to get the data hierarchically and generate layer.
But it is generating the new layers only at the top level. Is it possible to generate the layers in different hierarchy level, wherever it will match the condition?
That way if it is the case of adding lvt, hvt etc layers, mainly the device specific layers, that can resolve the hierarchical LVS issues also.
Please provide the solutions for the same.
Thank you for the support.
Subhabrata
  • stalapatra
    Hi Quek,
    Yes, the query was related to the previous script so I placed it there.
    With the new part, I wanted to read the hierarchy first and place the generated layers in there individual hierarchies, in place of adding the generated layers at the top level.
    I was looking for the suggestions with reference to the CCShierLayerOps procedure call. Here is the sample that I was trying to use:
    Looks like some variable calling is having the issue. Is it possible to cross check and provide the suggestions?
    procedure(CreateLayerHier(libName viewName inputLay1 inputLay2 outLayer opt size level @optional listOfCells)
    let((cv libId cellId cellList)
    libId = ddGetObj(libName)
    if(!listOfCells then
    cellList = libId~>cells
    else
    cellList = nil
    foreach(cellName listOfCells
    cellId = ddGetObj(libName cellName)
    cellList = append(list(cellId) cellList)
    );end foreach
    );end if
    foreach(cell cellList
    foreach(view cell~>views
    ;; using views matching viewName variable.
    if(view~>name == viewName && (cv = dbOpenCellViewByType(libName cell->name
    view~>name "" "a")) then
    printf("\nOpened view %L from cell %L of library %L for edit.\n"
    cv~>viewName cv~>cellName cv~>libName)
    foreach(shape cv~>shapes
    if((shape~>objType!="textDisplay" && shape~>objType!="inst" && shape~>objType!="path") then
    printf("\n Creating the layer %L. " outLayer )
    CCShierLayerOps(?cv geGetEditCellView() "inputLay1" "inputLay2" "outLayer" "opt" "size" "level")
    );end if
    );end foreach
    dbSave(cv)
    dbClose(cv)
    );end if
    );end foreach view
    );end foreach cell
    Subhabrata
  • stalapatra
    HI,
    I am waiting for the reply of my previous mail.
    As well I want to check, how I can block the generation of the layer, if the ouLayer is already placed based on the reference layer. Please let me know. Thanks for your support.
    Subhabrata
