  3. Invalid CDF choice
  • Replies 11
  • Views 22399
Invalid CDF choice
RVERP
RVERP over 10 years ago
I have been using some skill code where an instance (pcell) master is replaced with another pcell. The parameters are not the same, so I assumed all the cdf parameters are set to the default value of the new pcell.
I do this in combination with clones, doing following steps:
  • Generate all instances from a schematic
  • Select the group I want to clone, and generate synchronous copy clones
  • Descend in on of the clones, and replace the instance master.
These steps don't give any problems, in all the clones the master is replaced with my custom pcell.
But sometimes, while altering a parameter, I get an error message An invalid CDF choice "netlist" was specified for the CDF parameter "source".
My new pcell has a cdf parameter "source", a string. My original pcell doesn't have a cdf parameter "source", so I have no idea where this is coming from. This problem occurs on about 20% of the clonegroups I work on with above procedure.
I tried to do something with resetting or clearing cdf parameters, but with no succes. Any ideas??
  • RVERP
    RVERP over 9 years ago
    Thanks Andrew, I already tried do find the chapter explaining the attributes, but with no succes. Everything I know is learned with self study, it's a bit hard to search for something if you don't how it's called :)
