  3. How to use a custom netlist procedure (and OSSHNL-116 error...
  • Replies 13
  • Views 24947
How to use a custom netlist procedure (and OSSHNL-116 error)
PatrikOsgnach
PatrikOsgnach over 10 years ago
I would like to ask some information on how to desing and use a custom netlist procedure.
I have this scenario
A cell called mycell_1 (of library mylib) has a schematic view. In the schematic, I instance the cell mycell_2 (from the same library) and mycell_2 has a schematic and a symbol view.
Then, I add a config view to mycell_1 and select to use the schematic view for both cells.
Finally, I try to create a spectre netlist through adexl and all is fine.
Next, I add a new view to mycell_2, called "customnetlist" and of type "text". I don't fill in this view, I just want it to exist.
Then I call this function in the CIW:
(almSetNetlistProcedure "mylib" "mycell_2" 'NetlistTextNetlist ?view "customnetlist")
In the config view of mycell_1 I choose to use customnetlist view for mycell_2.
Now, when I netlist mycell_1, I get this error:
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'customnetlist veriloga ahdl spectre schematic av_analog_extracted av_extracted netlist', for the
instance 'I1' in cell 'mycell_1'. Either add one of these views to the library 'mylib',
cell 'mycell_2' or modify the view list to contain an existing view.
So, I must have forgotten to specify some other options. Can you help me?
  • PatrikOsgnach
    PatrikOsgnach over 9 years ago
    Very well, adding a net expression solved my problems (for now) and I don't have to use a custom netlister anymore.
    One last thing (I hope): is there a way to tell the default netlister to add an include statement when it netlists my view? Without defining a custom netlister, of course.
    I would like other users to be able to netlist my view without having access to my code.
    Thank you and best regards,
    Patrik
    Hi Patrik,
    No - you'll need to use a custom netlist procedure for now (I believe). We're due to be getting the native support for netlistable spectre text views in IC617 ISR9 (all being well), so then it should be doable natively with a "spectreText" viewType (and similarly for SPICE views, I believe).
    You could always put the custom netlist procedure in the libInit.il for the library containing your component; then it would be self-contained as that file will get automatically loaded the first time anyone accesses your library in a session.
  • PatrikOsgnach
    OK. I think we will include by hand what we need. Proper usage of dbCreateNet, dbCreateTerm, almSetTerminalMap and almSetTerminalList superseded avoids the need of a custom netlister.
    Thanks for everything,
    Patrik
