  3. Skill command to create the cell view?
  • Replies 11
  • Views 29267
niteshtripathi
niteshtripathi over 9 years ago
Hi everyone,
Using skill i have successfully created a library. Now i want to create the cell view so that further and i can add instances to create the schematics. What is the command to create the cell view. Thanks.
    Nitesh,
    That's why I have suggested in the last two appends using abInvokeCdfCallbacks or CCSinvokeCdfCallbacks - so you can update the properties and have it call the callbacks. Note you'll still need to know what the properties on the transistors themselves are called (they're not always called the same thing) in order to make it universal, but you certainly could make it configurable in your code.
