  3. Add an item ADE-XL results tab (when right clicking on a...
  • Replies 12
  • Views 25069
Add an item ADE-XL results tab (when right clicking on a test result)
PatrikOsgnach
PatrikOsgnach over 9 years ago
I have this scenario: in ADE-XL, after I load an old result to active, if I select the results tab and right click on a result, I have a nice menu with many options.
I would like to add an item to this menu. From what I read on this forum, I added this code to menus/spectre.menus
(sevAddMenuItemLists
    (lambda (session name)
        (case name
              ("&Results" list( (list "TestItem" ?disable nil ?form t ?callback "(testfunc session)") ) )
        );case
    ) ; lambda
) ; sevAddMenuItemLists
(procedure (testfunc s) (println (sprintf nil "Simdir is %s" s->axlCurrentDataDir)) )
but, when I right click, I get this message in CIW:
ERROR (ADEXL-2822): Invalid menu list structure "(false false)" provided.
Menu items must be specified as a list of ("menu name" "callback" {"true", "false"}), where the last argument specifies whether the item is disabled.
For submenus, replace the callback string with a sublist of menu items.
and nothing gets printed
What is the correct way to achieve this? I need to be able to access the "session" variable inside my callback
Best regards,
Patrik
    Patrik,
    In general you shouldn't need to know (for Cadence tools), and the way you are supposed to do this is via the information in the logFile - which is the "index" of the results directory. That's why there's no public API to return this information (I did check, but couldn't find anything obvious anyway).
  • PatrikOsgnach
    Ok, I understand. Point is that the option I'm trying to add to the right click menu will run an external (non-Cadence) tool on the data files and I need to know how they are called. Now, I'm parsing the logFile, looking at the dataFile field of all analysisInst entries and filtering out those that don't match selected analyses.
    Thank you for everything and best regards,
    Patrik
