  3. Running skill code using perl script
  • Replies 15
  • Views 24313
anandmohan
anandmohan over 9 years ago
HI,
I have a perl code, using that perl code is it possible to execute a skill code?
If any example is provided  that will be very helpful
Regards
Anand
    Anand,
    Well, if the wrapper script just has "virtuoso -64 &" at the end, it's not going to pass the -restore ... bit to virtuoso. You'd have to modify this wrapper script to allow you to pass in command line arguments to virtuoso. Just UNIX shell scripting - nothing to do with virtuoso...
  • anandmohan
    anandmohan over 8 years ago
    HI Andrew,
    Sorry for delay in replying to this post. (Was busy with tapeout work).
    Can you please tell me what modification I have to make in wrapper script so that command line arguments will get passed to virtuoso .
    Regards
    Anand
    Anand,
    Probably change the virtuoso line to:
    virtuoso -64 "$@" &
  • anandmohan
    HI Andrew,
    I modified the virtuoso invoke shell script as you instructed and opened a new virtuoso session. Then I tried to run my perl file given below
    test.pl:
    #!/usr/bin/perl
    print "start of program";
    system("virtuoso -restore print.il");
    print "end of program";
    print.il:
    procedure(pnt()
    printf("test line")
    printf(" ends")
    This time also it is opening a new virtuoso session, and in that CIW window I can see the print lines coming if call the 'pnt()' function.
    My problem is I have to avoid a new virtuoso session opening everytime if I run my perl script.
    Regards
    Anand
    Anand,
    The way I have done this is to use an approach similar to that described in this older post. I can't do all the work for you - this just describes the principle (and it does work) but hopefully you can get the idea and run with it.
