  3. How to quickly find device category?
  • Replies 13
  • Views 23107
MedAn
MedAn over 9 years ago
How  can I speed up the search of teh category name for device?
Now I wrote a small script:
ret = nil;
libId = ddGetObj(IndraInitForm->techLibField->value);
catList = ddCatGetLibCats(libId);
foreach(cat catList
   catId = catId = ddCatFindCat(libId cat "r");
   when(catId != nil
      when(ddCatIsObjInCat(cName catId) ret = cat);
   );end when
);end foreach
ret;
But it's take really a lot of time. Maybe somebody can show me another way?
  • TAMBUR
    TAMBUR over 8 years ago in reply to Andrew Beckett
     I am new to the community.cadence.com, many thanks to you as your solutions for different users queries are helped me a lot.
    Please help me to get solution for below query,
    Can we get list of cells under specified Category - MOSFETS (which has again a subcategory branches, like CMOS, DEMOS..etc)of a library. And I tried with ddCatFindCat, ddCatGetCatMemers commands, but failed to get cells if MOSFETS has many inner recursive subcategories.
    Thanks and regards,
    Basavaraj Tambur
    Andrew Beckett over 8 years ago in reply to TAMBUR
    Hi Basavaraj,
    Without writing something special, I could reuse this existing function I wrote a while back:
    *             (abTraverseCats lib catName cellTab)             *
    *     Given a libId, a category name, and the table we're      *
    *    using to collect the information, recursively traverse    *
    *   the categories to collect which categories are used for    *
    *                          each cell.                          *
    (procedure (abTraverseCats lib catName cellTab)
      (let (catId)
           (setq catId (ddCatOpen lib catName "r"))
           (foreach catMember (ddCatGetCatMembers catId)
                    (case (cadr catMember)
                          ("cell"
                           (setarray cellTab (car catMember)
                                     (cons catName
                                           (arrayref cellTab (car catMember)))))
                          ("category"
                           (abTraverseCats lib (car catMember) cellTab))
                          (t
                           (printf "Unexpected membere type %L\n" (cadr catMember)))
           (ddCatClose catId)
    You can then do:
    cellTable=makeTable('cellTable nil)
    abTraverseCats(ddGetObj("analogLib") "Sources" cellTable)
    listOfCells=cellTable->?
    Hope I've understood your question properly.
  • TAMBUR
    Thanks a lot Andrew! It works for me as I expected.
